Mds
Randy6666
Va
6.7 diesel
Do all 2020 trucks have mds bs
Ohio5pt7
Ohio
Hemis yes
Sent from my KYOCERA-E6920 using Tapatalk
rule18
Admin
NY
2017 Rebel
Anyone remember the last time a car manufacturer tried this? It was GM in the 80's or early 90's, the old "8-6-4". Huge failure.
Ridgerunner665
US
Both the 3.2 and 3.6 Pentastar engines were designed from the start with MDS in mind.
runamuck
Air Force
dfw
6.7 dsl
if you are talking about cylinder deactivation..eco mode..my '07 4x4 avalanche and my '17 sierra 1500 4x4 had it..my '19 laramie has it. I never had any trouble with it.
rule18
Admin
NY
2017 Rebel
No, I'm in the way back machine. Late 80's early 90's Caddy's (possibly other GM vehicles) had what they called the 8-6-4. Yes it was cylinder deactivation, but back then they had way more problems than successes. It wasn't received well and it didn't last long, in that iteration of it.
unxpctd
Minnesota
2021 PW 75A
On my 2017 Rebel when I'm on long trips or highways for stretches I let the engine do it's thing.
When I'm in town MDS gets turned off....really hate it in town. On the long road, no issues.
PoMansRam
East Aurora NY
I know this topic gets some impressive screen time, but I'm pretty sure the electro/mechanical cylinder deactivation system on Hemis, is the least of the engine's worries.
We know the cam/lifter issues happen on MDS and non-MDS hemis.
I do now my 2019 classic is the first vehicle I've owned with cylinder deactivation and being a car guy and noticing every noise and feeling, you can REALLY notice when MDS is happening. The only time I disable it is if I'm in a driving situation where I feel it's on/off on/off too much. Other than that I let it do it's thing. If you don't need to waste the fuel, why waste it.
Because of this system and the 8spd of course, if you're the type of driver that can get 23 or better MPG with a Pentastar powered Ram 1500, you'll get 21mpg with the Hemi. Probably not a big deal to some, but to me is amazing for a vehicle this size, weight, with an ancient designed V8.
mikeru
Super Moderator
Moderator Supporting Member
Eastern WA
2020 Limited
Hemi 5.7L non-Etorque
Sure, I remember that. Definitely wasn't around for long.
Found this after a very quick search...
https://www.autoweek.com/car-life/c...-good-idea-time-cadillacs-v8-6-4-engine-1981/
Jim Prendergast
texas
I have a 20 Limited with the Hemi 5.7 and on my sheet it has a $2,000 option for the e MV. Option trying to look up what that is it says it increases the horsepower to 315 and the talk what does all this mean is it any good question.I correct it the HP is 415
Elwood
Stockton CA
I think today's electronics make it work better, plus VVT and ECU etc
rule18
Admin
NY
2017 Rebel
I'm sure, this conv just reminded me of those particular bad old days (for GM, that is)...
