crazykid1994
hopefully this is in the right place But is it possible to separate the turn signal from the brake bulb or is it the same wire? Reason I’m asking is I’d like to remove the reverse lamp and run a full on led cube set up for reverse lights possibly recessed in the bumper and was figuring that if I can run a turn signal separate I could install an amber bulb in the reverse housing and wire that up for turns so it’s not empty. I tried using led drop in bulbs that are decent but I live where there’s no street lights and it gets dark. I know I could just tap the lights together but if possible not what I want to do
