more audio trouble !!!!
ramhunter9
ramhunter9
P-Star Jeep Wrangler
im going to use the 400.1 amp and go with 2 - 10's they are 4 ohm single voice coil.
and hook them up like this ....
i hope my amp can do this set up ? the amp rms is 200x1 at 4 ohm mono and each sub rms is 250.
and yes i have a aftermarket HU . 7" touch screen
quietpeen
2021 TRX
Hellcat
that will work. Each sub will get 200 watts.
When you had the sub hooked up....where was the bass set on your headunit?
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
so what 10s are you going with?
no word back from FOX........no surprise.
ramhunter9
ramhunter9
set a -10
also i just looked in the amp manual ?
200x1 rms is 4 ohm from the amp ... the pic above says 2 ohm ?
quietpeen
2021 TRX
Hellcat
not hearing back from Joe is probably not due to what you said to him. I've read a lot where people have complained about how long it takes him.
ramhunter9
ramhunter9
polk's to match my door speakers . going to have a audio shop build a box .
quietpeen
2021 TRX
Hellcat
set a -10
right with 2 4 ohm subs you will get a 2ohm load at the amp which will then push 400x1
you gonna go with a ported or sealed box?
ramhunter9
ramhunter9
so what your saying is i will be running 400 rms ?
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
99% of the time.
When you hit 88mph........some serious **** happens. Amps will then push 1.56 gigawatts more than they normally do! :birgits_tiredcoffee
ramhunter9
ramhunter9
**** i need bigger subs then . i thought i could put these polks in at 275 rms and feed them 200 rms at 4 ohm load with this amp ?
now im back to pushing a 2 ohm load ??? im sooo lost
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
dude - call me. PM'ing my number your way.
quietpeen
2021 TRX
Hellcat
no those subs will be good because technically each one will get 200 watts.
ramhunter9
ramhunter9
the book also tells me "one channel operation (mono) minimum impedence of 2 ohm while in bridged operation" ???
Bad Habit
Land O Lakes
Modded 4.7l
hearing back from joe at fox is like hearing froma old friend i sent him a email months i means ago with ?'s about a fox box then i bought one locally of a guy i found on dt, then emailed him again still no answer...its been how long since i got my fox box?.....good luck with this set up dave....
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
that just means that it won't go to 1ohm.
AF_Hemi
Central Jersey in person, the burgh at heart
2013 Ram 1500 CC 4x4 Sport
a 200rms amp with a 250 rms sub is a bad combination. you always want your amp more capable than the sub. A 400rms amp will have to work wayyyy less hard to power a 250rms sub than the 200 rms amp. Think of it in terms of potential energy. A 200rms amp will be giving 100% all the time, which creates a lot of heat and its really hard on the amp. A 400rms amp will only work about 60%, producing much less heat and overall better sound quality
ramhunter9
ramhunter9
thanks JJ for the help brother .
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
no problem Dave!
ramhunter9
ramhunter9
i found a set of tens that are 250 rms ... alpines ?? are they better than the polk's at 270 rms .
i know im trying to see what is a good sub thats 200 rms . its hard to find one thats 200 rms . and i have never owned alpine dont know if they sound good .
Arturo Rojas
