Morimoto headlights
mpress2570
The LEDs aren’t replaceable in any type of LED housing. Whether it’s a car with LEDs from the factory or after market led HOUSING or led projectors. If you were to have a problem they would send you a whole new housing and you send the bad one back. They’ll likely ask for a 50 to 100 dollar deposit and refund you when they receive the bad light.
Yeah unfortunately the pictures won’t come until people start receiving their lights. That being sad. The lights in the picture are morimoto LEDs so it’ll be very very similar to what you see in that photo.
Kinetic
That wouldn't be too bad then if that's how it will work, cuts a lot of downtime out of it. The fact that LED's are not changeable kinda sucks though, there will be some downtime no matter what, plus the hassle of swapping out your OEM projectors or whatever. For those that drive long distances, I hope it doesn't go out while you're 10 hours from home.
mpress2570
They aren’t actual led bulbs. They are diodes lined up and projected out. There’s no physical bulb to replace. But they shouldn’t ever go out. They should out last your vehicle.
Arth
2022 Ram 3500 Crew Cab Limited 4x4
6.7 HO Cummins Turbo Diesel
This looks great..... but that’s what I’m trying to say is the pics that are currently out just plain suck. We need pics just like this in real world. I get it this is not a ram and just an example but if it’s anything like this then they are on to something. We just have to wait to get some real pics that will tell the true story that’s all
Found this video. Looks like they are getting closer to production.
Arth
Double.
mpress2570
226635b278bd8f33e7ef24ecdf42879c.jpg statement from Morimoto regarding light output.
firebuff17
Ct
Just click on the link he provided. It pops up and then hit play. I don’t have FB and that’s what worked for me
Kinetic
Can't remember off hand but do the DRL's work on install or do you still have to have them turned on at the dealership?
JB1
Houston, Texas
From what I read there is no DRL, those lights only come on if you turn the headlight or parking lights on
Arth
I asked and was told that if you get your DRL activated the headlights are pinned to work with the factory DRL. If you don't have the DRL turned on they are providing a fuse tap so you can wire up the DRL to an ignition sourced power.
They said for testing purposes they had wired the DRL to the parking lamps.
Of course everything is just guesses until we actually start getting some.
JB1
Houston, Texas
Oh hell yeah that’ll be great then, I really would prefer a 100% plug-n-play
Anyone here preorder the headlights and taillights?
alphaprojects
