MotoFab lifted. May do control arms?
MoparFin
U. S. Navy Vet - AS1
PA
Just lifted my 18 Express with 2 1/2” MotoFab spacers up front and 2” in the rear. Doesn’t ride much different. Love the way it looks. May add control arms later. What brand control arms do you guys recommend?
MoparFin
MoparFin
PA
Powerstop towing brake kit on order for when we go out with this
Ohio5pt7
Ohio
I used RC when I ran the motofab worked good
Sent from my KYOCERA-E6920 using Tapatalk
ram1500rsm
Trabuco Canyon, CA
Will the mevotech ttx ucas work?
No, they're factory offset/lenght. When you add 2-3" spacers to the top of your struts, UCA's are not the only thing you need to worry about. 2-3" top spacers are not a good thing. See if the visuals can help you and others like you reading this stuff. 1/2" top spacers are ok. 2-3" are not. you're overextending components that were not designed to move down that much.
Rebelrouser
Cowtown AB
'22 Ram 1500 GT
Did you have to do anything with your struts/shocks/springs up front/rear? I'm also considering doing the same. Price wise it works for me as my truck is "pavement princess" so I 99% of the time it never leaves the pavement. Was a wheel alignment needed afterwards? Thanks......
MoparFin
MoparFin
PA
Stock struts up front and springs/shocks rear. I added the Mevotech ttx UCAs. Got an alignment. Have had no issues. Rides fine. Tows fine. No off-roading though.
