Muffler ?
RandyGallup
I have 2015 with the 5.7 and single exhaust. If I want a muffler replacement do I need a center inlet center outlet muffler or what? Sorry not by my truck.
bassheadhemi
Montreal, Canada
If you keep the factory tail pipe and DIY you will need center/offset or offset/offset depending on the muffler size. You will also need a 3" pipe and some 3" clamps. Ideally you should have a hanger welded to the muffler to help support everything.
For example the Flowmaster 50 HD center/offset, Magnaflow (22" 5x11) center/offset, Magnaflow (24",18",14" 5x8) offset/offset, Borla Pro XS (14" 4x9) offset/offset
There's direct kit available from Mufflex, they have 3 sizes depending on the sound level you want and used the Magnaflow 5x8 muffler (24",18",14")
Albany, NY
2014 1500 Laramie Limited
Is anyone using this 14" Magniflow by B2 Fabrication? I just purchased this for my 2014 Limited, duals out the back and waiting on it to arrive. Any ideas on the change of tone with a 2.5" inlet to 5" outlet exhaust tip? I was told to change out the factory tips but I don't really think I'd see that much of a difference and I am concerned about 5" tips rattling against the bumper, any thoughts? If you are using this muffler, how is the sound, I was told no drone in the cab if I use factory resonators and tailpipes. My wife is also concerned it will be too loud but I told her I'm not changing the exhaust on her CRV so she can continue to drive that!
Albany, NY
Sounds amazing, now just have to figure out what I am going to do for new exhaust tips. I noticed after me and my buddy got it all back together that the factory tips are in under the bumper about an 3/4 on an inch which can probably be rectified by loosening up the clamps and wiggling things apart but I don't feel like going through all that at this point. I'm just going to make some nice tips myself when I have some time.
