Mufflers
Flryder
Bradenton, Fl
Hi, I had a Magna Flow muffler installed on my truck and it is not too loud until I tow my camper trailer with the truck. When I tow I get a loud drone on the interstate. What I would like to know is can any one recommend a performance muffler that won't drone while pulling a camper at interstate speeds (70ish in Florida)? See below for the specs on my Ram.
Fast69Mopar
Which Magnaflow muffler did you install?
Is it dumped underneath or do the tail pipes come out the back?
You could install a short resonator behind the muffler to help with the drone.
lpennock
Army
Phoenix, AZ
5.9L & 6.7L Cummins
Install a short FTE resonator as far forward in the exhaust as you can. Or, replace the muffler with the long FTE. Either will take care of of your drone.
Sent from my SM-T350 using Tapatalk
Flryder
Flryder
Bradenton, Fl
It is a oval muffler, not one of the round ones. It is a center/offset inlet/outlet. It has 3 inch inlet/outlets. I can measure the body tomorrow.
Flryder
Flryder
Bradenton, Fl
The system uses the original pipe exiting behind the rear wheel.
Fast69Mopar
Okay. Like I said earlier along with @Ipennock, you can install a resonator to eliminate the drone or you could change mufflers all together but I'm guessing you won't like the sound of the quieter exhaust not.
One thing I do when pulling my camper with one of my Hemi trucks is get to a cruising RPM where I experience the drone and then I back off 200rpm or accelerate 100-200rpm to help with the drone.
Firebird
2019 Ram 2500
This is why I haven’t pulled the trigger on a muffler yet, I definitely don’t want drone while pulling the camper
