mystery button help needed
goonbash
Banned
2016 2500 Longhorn Limited Megacab
cummins
Hi there. I think it is an add-on because it is not in the manual but this button is on my used 2016 Ram limited cummins 4x4 mega cab I just bought.
Can anyone tell me what this is/does?
Thanks
ScottFL
U.S. Navy Gulf War Vet
2016 RAM 1500 Laramie Longhorn 4X4
HEMI 5.7
For sure after market, what happens when you press it?
MADDOG
Living in a Firepit
Looks a bit like some sort of alarm system. What does your fob look like?
McBroom
Denison Tx
Hemi 6.4L
Starter disable?? Fuel cut off??both could be theft deturants
I Love My 2018 RAM 2500HD 4x4 Off Road. 6.4L. USMC (ret)
goonbash
goonbash
Banned
cummins
It does nothing that I can see, hear or feel. I tried it with accessory on, and with truck running. No messages or light on dash, no light on the unit itself, no chimes or dings.
These 3 wires come off the back of it and run straight upwards toward the steering column and instrument cluster.
goonbash
goonbash
Banned
cummins
My Key fob is normal dodge dealership type
goonbash
goonbash
Banned
cummins
NOT attached to the switch but deeper under the dash in the same general area is this fuse spliced in that doesn't seem factory either.
bdcramer1
Delaware
Could be a turbo timer. Try pressing it, and then shutting the truck down. If it's a timer the truck will continue to run for a bit before it stops running. They keep help save the turbo bearing from coking up.
goonbash
goonbash
Banned
cummins
No manufacturer name on it, back looks like this.
Seems like too obvious a spot for ign cut or fuel cut right?
ThunderMug95
North Prince George, VA
The reviews on it are all over the web. Evidently its a dealer add-on. Starter interupt switch. If you google it, then select IMAGES, you will see pulls from a bunch of forums with folks asking the same....What the hell is this?
goonbash
goonbash
Banned
cummins
Thx I finally saw the same switches under images.
So I guess mine must have the inert chip that disables it. So they hacked into all that wiring and it does nothing and isn't worth having. Great!!
ThunderMug95
Yeah. Sorry. All that tapping in there.. id unscrew it and ziptie out of sight if it bothers you. Just buy a Pedal Commander and install it over the holes!!!
goonbash
goonbash
Banned
cummins
Throttle response improvement is on my list, do you run one? I read great things about the level of improvement. How do you set yours? Thx.
Ramtruck16
Blue Springs Mo
If the truck is a former rental car, its probably a gps tracker and call for service button for the remtal agency.. i seen one similar to yours on a Ram rental i had a few months ago..
