Navigation issue
mossyoak03
portsmouth, va
Recently put in the uconnect rer navigation system. I bought it used from a guy in California. I've changed the state and my home address and it still says my current location is in CA! How do I fix this? Pic for the system reference
mossyoak03
mossyoak03
portsmouth, va
Hooked up all three things that was ok the other stock one.
Etroze86
Grand Forks ND
Not sure if all trucks are wired with the sat antenna so that maybe your issue
mossyoak03
mossyoak03
portsmouth, va
No the other stock radio was just a radio and CD player. The satellite antenna is suppose to be inside the unit from my understanding.
jwheeler
Washington
If you had the res before, I think you will need to add a gps antenna.
Jared4.7
Olathe, KS
2017 Bighorn CC
What year is your truck and which nav unit? Newer units use a combined nav/Sirius antenna (SDARS). 2011 and older didn't have the combo antenna, 2012+ did.
Jared4.7
Olathe, KS
2017 Bighorn CC
Did you use the little standalone GPS antenna?
mossyoak03
mossyoak03
portsmouth, va
Not sure this is the back of my old radio and everything that was on this was plugged into the new one
jawzs2
Air Force
South Jersey
The RER has a blue connector for the NAV, if you didn't hook an antenna up to that, it won't get a GPS signal
mossyoak03
mossyoak03
portsmouth, va
I didn't hook anything up to it. I just ordered one thanks a lot
mossyoak03
mossyoak03
portsmouth, va
Could I use the satellite antenna as the gps antenna?
jawzs2
Air Force
South Jersey
Not sure, you might be able to if the connector matches up. As another member posted, the 2012 SDARS antenna does both, it might work, but then no Sirius radio
mossyoak03
mossyoak03
portsmouth, va
I don't listen to Sirius anyways haha
