hunterdan
- May 7, 2018
- 702
- 608
- Location
- SE PA
- 2019 classic
- 5.7 Hemi
I found a method to delete the ags for under $1, without having to pull the ags motor apart and reclock the lever arm. Need an 11/64" drill bit (or one big enough for a an 8-32 screw), an 8-32x1.5" screw and 4 nuts for said screw.
Remove the ags assembly and pop the motor out. Drill out the top divot where the locating pin for the case is (where most kits have you drill out). Thread 2 nuts on to the screw all the way to the head. Pop the screw into the hole you drilled with the head and nuts on the same side as the lever arm. Then simply lock the screw down with another nut or 2 to keep it from working loose. This essentially mimics the same amount of travel the arm would go through while still in the ags assembly, so no trimming or moving the lever arm is necessary. Once that is done, plug the motor back in and mount it somewhere out of the way. I had originally made a spacer out of stainless I was going to use, but it ended up being to thick in diameter and didn't offer enough travel. The nuts were slightly smaller and did what I needed them to do. Made a few trips and key cycles with no check engine lights. Took longer to take the ags assembly out and fish the motor out of it.
The stainless spacer you see is simply to take up any extra thread on the screw and really isn't needed.
