Need help Asap
TradesmanGuy
Marine Corps
PNW
PentaStar V6
Ken226
Washington State
Yea, looks like a 4.7 v8 with a broken or worn out chain guide, or maybe a chain that's stretched beyond the limits of the tensioner.
It should look like this:
TradesmanGuy
Marine Corps
PNW
PentaStar V6
That would detonate the engine with valves colliding with the tops of pistons. And that chain looks broken, so there would be no valve movement and the engine would be dead.
Ken226
Washington State
The 4.7 v8 is an overhead cam engine with a cam under each valve cover.
There are 3 timing chains. The chain he is pointing at in his video is the passenger side chain that transfers power from the center sprocket to the passenger side overhead cam.
Im not sure what your talking about, with regards to the broken chain.
Are you seeing something that i missed?
Grams
2024 & 2015
6.7 Cummins & 5.7 Hemi
Just replaced both the hydraulic tensioners and put everything back together the clicking is fixed thank you to everyone with the help and suggestions
THANKS…for posting-back and letting us know.
What did that cost you?
FYI, I had a ‘12 Ram 1500 w/220K miles on a 4.7 and that engine gave Absolutely ZERO troubles. It got regular dino-juice SuperTech 5W20 every 5K miles, used cheapo SuperTech filters, and had spark plug changes at 100K each time….(and they really still looked just-fine each time I changed them)…. Great engine…if slightly underpowered for towing RV’s …but it only did that a couple times/year.
I really really REALLY had planned to keep that truck until the cemetery …. but an older man ran his read light and totalled it out…. :confused:
Why am I telling you this…? …. in order to support your decision to repair it rather than dispose of it. Those are the very last engines which were designed by American Motors before Chrysler acquired AMC…and they were made in a dedicated engine-assy-line. Great littl engines…both the 4.7 V8 and it’s 3.7 V6 little bro.
Here’s a pic of it at work in far West-Texas Terlingua area:
H
Hershey Squirts
Georgia
It was 150 for the whole timing chain kit and gaskets that’s it and yeah I love this truck i wanna keep it as long as I can
TradesmanGuy
Marine Corps
PNW
PentaStar V6
Looks like the link rivet on the top is not attached to another link. Not sure what I'm look at then. :oops:
RamDiver
Marlborough, Ontario Canada
2021 DS
Maybe your monitor requires a tweaking of the brightness, contrast and sharpness settings. :cool:
The source material is marginal for increasing the size, but it sure looks like another link to me.
Ken226
Washington State
I think I understand the confusion.
You don't see the next link on the chain because it is obscured beside the engine block casting, where it passes through an opening, to continue up through a corresponding opening in the cylinder head, then the top of the cylinder head and the camshaft sprocket.
Dusty
Rochester, New York
The 4.7 was a great engine!
The powerTech engines, however, were designed and came out well after Chrysler acquired AMC:
Regards,
Dusty
2019 Ram 1500 Billet Silver Laramie Quad Cab 2WD, 5.7 Hemi, 8HP75, 3.21 axle, 33-gallon fuel tank, 18” wheels. Build Date: 3 June 2018. Now at 150522 miles.
Grams
2024 & 2015
Regards,
Dusty
“The initial design development for the PowerTech V6 and V8 engine family was done by American Motors Corporation (AMC) and debuted in 1998 with credit to Chrysler. This was the first new V8 engine for Chrysler since the 1960s.[2]The companion V6 was basically the V8 with two fewer cylinders, another concept that originated at AMC before the company joined Chrysler.[3]These new engines had nothing in common with the Chrysler LA engineV8s, nor the Jeep 4.0 L "PowerTech" I6 engine.”
A 4.7 L V8 came
Dusty
Rochester, New York
A 4.7 L V8 came
My apologies. In my haste I did not see the second paragraph on my screen.
Regards,
Dusty
Marshall
Sk, Canada
2014 sport
On my lap top it looks OK to my old eyes, mind you I damn near got sea sick from the hurry up jerky clip that H posted. slow steady would be better. ;)
Glad it turned out simple fix.
I never had one of these, but a fellow had on in a Dakota truck and it was a snappy unit. He really liked it.
Grams
2024 & 2015
Regards,
Dusty
Thx, but no apology necessary.
Another interesting read on how Chrysler continued to modify and improve the 4.7/3.7 engines is: https://www.motales.com/engines/LA-based/Next-Generation.php
Dusty
Rochester, New York
That was a very good read. Thank you!
My '03 Dakota had the 4.7 motor and I found it had exception torque. It was also about the quietest motor I ever owned. Completely trouble free all the way to 148,000.
Regards,
Dusty
04fxdwgi
Coastal NE North Carolina
2016 1500 Sport
LOL. When the Rambler name was changed, it was believed the name of American Motors was chosen because the Ramblers had parts from every other OEM in it (with the exception of some of the engine basics) The 390 / 401 had a Ford dist, a GM alternators etc, etc. The Rambler AMX and the Scambler were crazy performance cars with 20/20 foresight for new ideas and innovations. I won a few $$$ runs with my brothers '68 AMX 390 4 speed.
My brother restores Rambler / AMC performance cars in AZ and I have worked on lots of his stuff for him before he moved out there.
Austinv
