Need help urgent!
Luke(MI)
Banned
1998 Chevy Blazer
4.3l Vortec V6
Ok so I blew the rear U joint on the rear drive shaft at the mud bog yesterday night so I threw the drive shaft in the bed and pulled it around back with another truck, and limped it the 3 miles home at 5:30 this morning. The U-joints on the front axle are going as well so I don't want to push them any more than I have to. So, can I steal the U-joint out of the front drive shaft and take the front drive shaft off, and use the u joint on the rear so I will have the normal 2WD long enough to get my truck to town and get all new joints? Everybody is at work and I need all this done by 12:00 noon tommarow so for this emergency can I do this? Thanks in advance
Luke(MI)
Luke(MI)
Banned
1998 Chevy Blazer
4.3l Vortec V6
Nobody? I hate to be impatient but I need to get to work tomorrow
Bigtman07
Registered User
Piqua, Ohio
Cummins 5.9
I don't see why not.
Sent from my DROIDX using Tapatalk
ramthis9501
Oklahoma
5.2 V8
Dude you havent had much luck mudding lately... lol
LB3711
Trumbull, CT
3.6L V6
both drive shafts use the same u joint? i would think they are different because the front driveshaft is smaller then the rear.
Luke(MI)
Luke(MI)
Banned
1998 Chevy Blazer
4.3l Vortec V6
Front Driveshaft is only shorter, pretty sure the Joints are the same size
Luke(MI)
Luke(MI)
Banned
1998 Chevy Blazer
4.3l Vortec V6
I wasn't mudding when it broke, I was driving from the campers down to the mud. I had already pulled three trucks out of the mud before though, and had been stuck three different times. all part of mudding though. If mud ain't flyin you ain't tryin.
05singlecabHEMI
Lilburn,GA
daily drivers shouldnt see mud. im kicking my ass right now trying to get mudd out of places i never knew were on my truck.
adamwilkes14
When you replace them, make sure you get greasable replacments, even if it costs more...and just do them all while your at it...especially if your putting it in the mudhole...then everytime after you go mud slingin, grease the hell outta them.
Luke(MI)
Luke(MI)
Banned
1998 Chevy Blazer
4.3l Vortec V6
Every time she sees the mud the underside sees the pressure washer and grease gun, ALWAYS. On top of that I grease the entire front end every oil change, and every tire rotation
