Need help with Fluids
426power
BRUNSWICK, Oh
Guys I need your help. I am changing the dif fluids front and rear. Going with Mobile One as it has never let me down. Question is how many quarts does each diff take. I checked my truck and the owner manula is gone. Also what does the transfer case use for fluid and what quanity? Thank you in advance.
HuskerRam
Tucson, AZ
3.0 Ecodiesel
Should be around 2-2.5 in the front and 4.5 in the rear for the HDs. You can use the Amsoil website to get fluid capacities for your specific truck. I'm not advocating the use of Amsoil, but it's a good tool on their website.
danielmid
Southeast WI
2015 Sport 4x4
Plus you get to do some math!
I'm advocating their fluids and their site for capacities.
JW2 Innovations
Preferred Vendor
Olive Branch, MS
2016 Ram 2500
I recently did front and rear diffs on my 2016 2500 6.7 and it bought 4 quarts for rear and 3 for the front to do the job with standard differential covers. Some after market covers add more so if you have them check with manufacturer and add that on to oem amounts. I did have a little left over for each one, but these quart amounts on OEM will make sure you have enough by being into the last quart when filling.
Here ya go pard, free version your owners manual, pdf.
Transfer case just loosen top nut first, do not over torque any transfer case nut, those cases will crack. That's all you need to know, unless you remove cover to scrap, all of those items are just tighten bottom nut after drain and fill til it drips, done. Just order a little extra, it stores well. I don't know what m1 is correct for that t case, redline c+ or amsoil multi use transmission fluid have worked well in those. The mopar stuff is just over priced fluid, up to you.
426power
426power
BRUNSWICK, Oh
what are you using for fluid in the transfer case other then stock. anything other then Amzoil ?
redline c+ is in mine, it is however a different t case. Ask @Hemi395 for your question, he has done the work on this. If you want to stay with m1 I am sure there is an option out there, I just don't know it. Agreed their diff fluid is very good if not great.
Hemi395
Cape Cod MA
Which transfer case do you have, one with 4Auto or without? The fluid requirements are different....
White six four
Wisconsin
I put valvoline atf+4 in my transfer case. Had a couple quarts leftover from changing the trans fluid.
I dont think the hd's have 4x4 auto. Just 4 lock and 4 lo
ThunderMug95
North Prince George, VA
Im planning to do my ZF next weekend…delayed by a a crappy cracked fluid transfer pump…I plan on Valvoline max life in both the ZF and BW44.
Brent 1955
Kansas
3.5qts in the back if you have an 11.5" rearend 14 cover bolts and make sure you use limited slip bottle I buy mine from Ram dealership if you have a limited slip rearend. Front end is about 2 qts. I use Amsoil 75 90 full synthetic plus a qt of Lucas. and transfer case I always use Valvoline transfer case fluid. it is alot cheaper than a quart or ram transfer case oil at 40 bucks a quart andit takesabout 2.5 quarts there abouts. I have a2013 Laramie Limited Edition 3500. I change my gear oils every 2 years if it needs it or not.
HEMIMANN
Minneapolis, MN
2017 2500 Laramie Crew Cab
Limited slip additive isn't needed in the rears of 2500/3500's since there's no clutch packs.
Thought I'd read somebody say Stellantis cost-reduced by changing axle suppliers from AAM back to Dana with limited slip clutches? I don't recall what model year, but I'd definitely recommend people paying attention to what their owner's manuals say. For an AAM with a true gear locker, the manual will state limited slip additive is not required (and in fact is not recommended by the axle makers).
White six four
Wisconsin
Sounds like aam is here til 2030.
I did just read on another site that the 45/5500 uses or used the Dana rear.
HEMIMANN
Minneapolis, MN
I get so confused with manufacturers toggling suppliers often. I'm sure I read something about it somewhere on the Forum not too long ago. I remember lamenting the loss of the TracRite GT torsen all gear differential, and saying something about staying with my 2017 instead of buying new.
Hope I haven't gotten too senile.
up to the end of the production year 2010, Ram 1500s used the
AAM 9.25 rear differential
all 2011 + Ram 1500s used the ZF 235 mm / 9.25 rear differential, ( ZF Friedrichshafen AG )
i won't swear to this, but
most of the 2500 and all 3500 Rams use Dana 60 front axles. The 1500 Rams and some early light duty 2500 Rams used a 9.25 Chrysler (Spicer) axle in the rear.
A Dana 60 rear axle was used on heavy-duty 2500 V8 Rams.
( some pre 2011, 9.25 differentials were marked )
Chrysler on the Build Sheet, they were the SPICER 9.25s
Others were marked AAM 9.25 on the build sheet
EastWestHemi
Out West
6.4 w/4.10s
i changed my front and rear diffs to chevron delo 75w90 synthetic. I chose is specifically because of price and also because the Mobil, valvoline, castrol, etc all have limited slip additive, which 2500 and 3500 don’t need. Good luck, not sure if the limited slip with hurt anything. I’m going to use valvoline multi vehicle atf in my transfer case this spring, 2500 with BW 44-47.
426power
426power
BRUNSWICK, Oh
Ok guys I have a 44-46 transfer case in mine. The dealer ran my vin. I was able to use the ATF +4 in it. I did put the Mopar conditioner in the rear diff. Thank you all for the information. Much appriciated. Good group of guys on here.
