morc66
I recently purchased 2018 6.4l Hemi Powerwagon. Been having some issues and not happy with the response from the dealership. In brief: lockers take forever to engage (last test we drove about 1/4 mile, they didn't engage) Dealer says that's because they are fluid operated and need time to build pressure, and you have to turn them before you know you need them.
Shift change to 4 lo. Never heard a noise like it. Actually made a guy jump last week when I shifted into 4Lo. Throws the truck side to side and feels like the transmissions being torn out the bottom, of the truck. Also get a horrendous jump down on gear change.
Horrible grinding from front end, sounds like ball bearings in the diff. Happens occasionally in 2wd if the rear is slipping, happens in 4wd, with or without lockers.
The dealership has said everything is as it should be.
I've been offroading for 10 years and I'm used to the equipment so I have my own opinions. I'm looking to see if anyone has similar experiences or can give me mechanical feedback.
Thank you.
Thank you.
