Needing assistance
JDM
Magnum 5.2l
New to this forum have clicked in every now and then trying to fix my truck. I have a 1994 5.2 4x4 reg cab long box with 227,*** miles.
Things replaced right of the bat: topped of antifreeze and brake fluid, 4 new tires, few trim peices, and transmission fluid/filter and oil.
From the moment I saw the truck the only known issues were leaking transmission fluid and spongy brakes. It fires right up all the time, in any weather.
When the truck started acting up I was driving on the highway 55-60 mph and low on gas. As I cannot recall all that happened, Ill try my best to give all the information I can. It bucked and sputter as though it was running out of gas. Pulled over, turned it off and was waiting to have a gas can brought to me and decided to start it on a whim. It fired right up. I decided to drive on to a gas station (3 miles) Noting the truck would not go over 3000rpm. Put half a tank in and some injector cleaner, no change. Not going over 3000rpm was not a significant hinderance at the time, daily commute round trip is 30 miles. Half of that is gravel and fastest I go during the trip is 60mph. It slowly got worse, wouldn't go over 2500rpm. Now it will not go over 2000rpm.
Not going over 2000rpm is an issue, as I can barely get up to legal highway speed. Things I have replaced or checked since include: fuel pump replaced, plugs/wires, oil. Checked or swapped with known good parts: tps and map sensor. Compression on all cylinders, worst being 110psi best being 150psi and the rest fall between. Unplugged injectors one at a time and observed the engine bogged downthe same on every injector. Removed catalytic converter to no avail. Only codes showing are 12, 37, 34, 51, 55. The check engine light does not remain on after the bulb check.
So for a final breakdown the problem is:
Won't go over 2000rpm without sputtering and bucking but won't die. It does this in any forward gear and park and neutral. Cuts out quite a bit in reverse, still does not die. It idles great, fires up great, at a loss up to this point. All plugs are firing.
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
What do those codes show? I don't have access to my 95 manual atm
BBartow
New Port Richey, Florida
5.9L Magnum
34 = Speed control circuit or speed control switch always low or high = An open or short in the speed control vacuum or vent circuits. Speed control switch input above or below normal range.
51 = System lean L-Idle Adap at rich limit or lean R-Idle Adap at rich limit = O2 sensor signal indicates lean air/fuel ratio during engine operation. The computer ran the mixture to the rich limit of programming, but the O2 sensor still indicated a lean condition. L or R indicate left or right side O2 sensor. Fuel pressure problems can lean the mixture and set this fault.
J
JDM
Magnum 5.2l
I had the o2 sensor out before I knocked out the catalytic converter to see if it would help. I figured that might be what tossed the 51. Thoughts?
J
JDM
Magnum 5.2l
And I believe the 34 is linked to my cruise control? Which is not hooked up.
djturnz
5.9 Magnum
Clear all codes. Make sure they are cleared. Go for a spin. As soon as it acts up, pull over and check codes again.
My 94 RAM would run fine, and then act up and eventually die. After a few minutes it would start and run again for a while. I had all sorts of codes. So I cleared the codes and ran it until it acted up, pulled over and checked. Only 1 code (O2 sensor) came up. I replaced that, and it never acted up again. It seems the O2 sensor was causing all the other codes.
J
JDM
Magnum 5.2l
Cleared codes, no dice. Haven't drove it but still won't rev over 2000 without kicking and sputtering.
djturnz
5.9 Magnum
Now you need to drive it to get it to throw a code.
I'm not very familiar, but could this be "Limp mode"?
J
JDM
Magnum 5.2l
I will have give that a shot when I get home. The light is never on when I drive, which is odd to me. It won't rev over 2000 even when it is not in motion, so I was wondering about a "safe" mode for the engine more than the trans. (Limp mode)
J
JDM
Magnum 5.2l
Anybody know of any tell tale clues as to if the timing has skipped without pulling the truck apart?
J
JDM
Magnum 5.2l
Also wondering if anyone had any info on the fuel pump mounted rollover valve. I capped the vacuum line because I broke the nipple on the valve.
Rustycowl69
2001 ram 3500
V10
basically you'd need dial indicators, a degree wheel, and know the cam events data for your particular engine. It's pretty involved procedure, but it can be done. Look up on the Internet how to dial your cam in.
Rustycowl69
2001 ram 3500
V10
If yours was a later model, I would think that if the cam position sensor and the crank sensor disagreed (out of cam timing), it would throw a code. But I don't KNOW about your year, so maybe someone else can pitch in here with a more informed comment.
