fifteenhundred
- Dec 8, 2013
- 9
- 0
- 1999
- 5.2L 230 hp V8
Hi everyone,
I recently bought a refurbished/reprogrammed powertrain control module (PCM) online in response to a check engine light code of p0601. After installation, the check engine light went off. However, at random times now while driving, the engine will turn off. I can immediately crank the engine back up and start driving and make it home without it happening again. I've read previous forums on the pcm and I'm NOT having the "no bus" error reading on the odometer.
So, I'm wondering if
1)the PCM isn't programmed right and should be returned
OR
2)the now working PCM is gathering data, something else is not working, and the PCM is shutting the engine off....is this even a possible explanation?
Has anyone had this problem? Thanks for reading!
OR
