New Leveling Kit
99RamSport360
5.9L Magnum 360
Alright, so it's time for me to buy a front end leveling kit. I have a few questions first. Are steel better than poly?(heard that the poly settle) Do I need to replace the rubber isolator? Do I need new shocks with just a 2inch level? I am planning on buying the two inch spacer from HBS. My front end sags a bit from the brushguard, and the front end will have to be realigned right? Any input and pictures of trucks with spacers and installation would be great!
Thanks.
Hollabakzach23
Lafayette, IN
Thanks.
I went with a HBS 2.5 inch level and it lines up almost spot on. I had the poly level on my 2wd ford. It did settle and I lost about a quarter of an inch on the front. You will use the stock rubber isolator and reinstall that. You don't neeeeed new shocks idont think but you're already down there so get some that apply for the amount of lift you go with. For example, I got rancho shocks for 0-2 inches of lift. Get an alignment afterwards and your set!
ImageUploadedByTapatalk1351620767.949436.jpgImageUploadedByTapatalk1351620780.549698.jpg
There's some angles for ya and you can see the shocks but not the spacers very well. Ill try and get some close ups for ya.
99RamSport360
99RamSport360
5.9L Magnum 360
View attachment 8494View attachment 8495
Thanks man, what was the install like? Did you put anything on the rear either?
Hollabakzach23
Lafayette, IN
Install was super simple because of those shock towers.
Basically remove the shock. Compress the spring. Remove the shock tower. Pull the spring out. This is where it got fun, I had to jack up the front end some more to get the spring and the spacer to both fit in there but it wasn't much more. And then install the shock tower and shock and all that. That's basically in a nut shell don't follow those directions as I did that almost a year ago. Lol I followed a write up from some site I think here maybe. But I didn't do anything to the rear because it would be unlevel and I'd be back to square one. Lol I do intend to replace the rear shocks though as mine are starting to go out and I want them to match.
99RamSport360
99RamSport360
5.9L Magnum 360
If you find where you followed those instructions, it would be great if you could point me in that direction. You had to put the frame up on jack stands and then lower the front axle with a floor jack right? If someone could find a step by step picture thread or set of instructions, that would be great
Thanks.
Hollabakzach23
Lafayette, IN
Yeah that sounds about right! It may not have been from this site so ill PM you if it wasn't. If it was ill post here!
Hollabakzach23
Lafayette, IN
I think I lied to ya because I remember this picture!! But here's the HBS instructions from their site. Ad they're a vendor so I think I should be able to post the link here. If not, could the mods take this down! But I'm pretty familiar with the front end parts too so if you need some clarification or anything let me know!!
http://www.hellbentsteel.com/Instructions/110-000-1001_Dodge_Ram_R04.pdf
