Nitrous install
onebadbee
Bottle mount
line visible in cab only hear i used the bolt hole from the jack as the hole
nmu mount
getting the line figured out
Is that the zex hemi kit 82176? I have been looking at that one off and on.
AParrette
St Augustine, FL
1997 Pontiac Grand Prix
3.8L SUPERCHARGED
only gonna do one side for the fogger?
you could get a tb spacer for a fogger instead
4.7Ram5.7Rango
Lynchburg, VA
4.7 Flex
That 12.86 is stroking...... 2wd or 4wd? Im assuming you have a helluva tire under there to pull that short time.... Whats it trapping?
Just curious, you dont hear of too many rams running in the 12s, much less n/a! Badass truck my friend, good luck with the N2o
truckin151
2013 sport
^^^ you'r not on the right sites then....
OP - You trying to hit the 11's
onebadbee
onebadbee
not doing a throttle body bore i need this accessible to change jets immediately
going for 11s with a 100 or 125 shot
yes thats the hemi kit that i got its pretty self explanatory but i got mine used for a steal a leg and an arm
4.7Ram5.7Rango
Lynchburg, VA
4.7 Flex
Guess not, this is the only Ram/dodge one Im on. I venture over to the 'other' one from time to time, but even there I didn't hear of too many of our trucks running those times.....
When are you taking it out?
I look forward to hearing how the kit works for you. I have been thinking about getting that same kit for next spring.
onebadbee
onebadbee
once i break 11s its up for sale
Gary's Hemi
Walker, La
:birgits_tiredcoffee
