No power and bad gas mileage
Crow1771
Illinois
Needing some help. I have a 2013 ram 1500 Hemi. Started out acting like a spark nock and missing no codes where thrown. So I replaced all spark plugs didn’t help anything then a code finally thrown a miss fire on cylinder 3 so I replaced plugs and replaced all of the coil packs. Started acting better but still no power and gas mileage is still bad. Checked truck out with reader the only thing I can see is both fuel rail banks are testing on the high side. Any advice will be grateful and thanks for you time.
Nick_rp
I=V/R
puyallup, wa
5.7 Sport
High fuel pressure will cause you to run rich which decreases fuel economy and poor engine performance, both which you describe.
If fuel pressure is the cause your exhaust maybe black, smell fuel from exhaust, spark plugs black/wet.
Most likely culprit would be a restriction in the fuel return line like a kink.
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
I'm not sure how to check the fuel pressure,
if you want to change the fuel pressure sensor
You may want to view this video first
C
Crow1771
Illinois
Fuel pressure is reading 57 to 58. No smoke and doesn’t smell like gas. Could this be injectors, or fuel pump.
