No Start Issues 2003 Ram
djstensgard
Rochester
Thanks for looking,
I have a 2003 Dodge Ram 1500 4x4 with a 5.7. I recently changed the oil and filters on my transmission and parked the vehicle. I went back to start it and it would not start. It will turn over and popped the first time I tried, but now it just turns over with no start. I have done the following:
-no codes using my cheapo code checker
-put more gas in the tank, no start
-plugged in my spark tester. the piston I tested is getting a spark
-checked the fuel pump relay and fuse. I swapped them with other similar ones, No start
-could NOT hear the fuel pump pressurizing when I turned the key on/ no run
-disconnected the gas fuel line at the driver's side fuel rail. put the line in a bottle turned over the engine, no gas
-I spliced into the green/ white stripe (fuel pump power 12v) at the fuel pump. I attached my power probe to the battery. I turned the vehicle to the on/ no run...no volts no change. I turned the vehicle over and no volts and no change.
Thoughts?
