Non-lifted 4th Gen with bigger tires
Drummin4jc
WWG1WGA!
SW Pennsylvania
2024 Ram 2500 CC
Brand new to the board so I hope this is where this post needs to go. I've been searching and haven't found what I was looking for...
Recently purchased a 2012 Dodge Ram 1500 4x4 with 1.5" spacers in the front. I'm wanting to do new wheels/tires in the near future but didn't want to do a lift on the truck. I just wanted a nice set of wheels and tires to go onto the truck the way it sits. So, I was looking to see if anyone had pics of their trucks with bigger tires on them without a lift to give me an idea of what it would look like.
I'm leaning towards the KMC XD series XD811's, 20" with a +18 offset. For tires, I was thinking of going with 305/50 R20's (33/12.50 R20). Your thoughts an opinions are greatly appreciated. Thanks!!
Your truck looks great and nice job dipping. Love the XD's especially 6 to 8 spoke my personal preference. And 33's is a great choice as well, will fit no problem that I know of up to 12 wide, maybe past that too but I know guys running 12 no issue. You may want to upgrade to Bils 5100, you can read my experience in my sig. Small upgrade but your truck will drive better. No pics yet because as you know I'm still rocking the factory tires, want to get some use out of them for a bit.
BOWERSFJ
Uniontown OH
You need to find something around zero offset to run 12.50" wide tires or the inside of the tire will hit the suspension . . . Stick your hand over the top of the tire and down between the tire and suspension . . . That's how much room you have . . . Your factory wheels are +18, and that's a 10.50" wide stock tire . . . I'm running 12.50's on zero offset wheels, and I have about a half inch of clearance
N1ck
Regina Sk
33x12.50x20 federal mt on stock wheels painted black with 1/4 RCX spacers on the front.
Caldwell
Philadelphia
305/55/20 = 33/12.50/20
wanted you to have the correct info OP. the size you posted is a 32''.
RyanJM
Houston
2014 Express RC Black Edition
You want closer to a 0 offset or +1. +18 on a 20x9 with a 305/55 or 35x12.5 may clear with a AT but nothing with side biters. I know from experience. No UCA rub but it loved running the sway bar on sharp turns.
BlackRamHemi
Edmonton Alberta Canada
305/50R20 General Grabber AT2's 32" x 12.4"
Stock 14' Sport Alum wheels (20" x 9") +19 offset
10' RCSB 4x4 Sport with 2/3 Ground Force Drop
no spacers, no rubbin
SWAMP RAT VII
YOLO,CA
2017 RT
Nice Truck. I notice a cover on your bed. What brand might that be?
Patriot_907
Completely stock suspension? The RCX Spacers, those are for offset, right? Or is that for leveling? (Sorry I'm a noob)
Galion
Edmonton, AB
I just got a set of amp MT terrain masters 305/55R20's on mine on stock 20" rims, no spacers, no rubbing at all.
BOWERSFJ
Uniontown OH
I believe he is talking about wheel spacers ... You will need them to run 12.50's on factories ... Don't go ebay cheap on them ... Make sure they are hubcentric
Sybil
I have a 2011, will these tires fit my stock rims? Need new tires . Getting new wheels eventually...
BlackRamHemi
Yup, the old Sport Wheels are the same offset/size
I ran 305/50R20 Nitto Terra Grapplers on my last set
At 32" tall they really look better on a lowered truck though
....never been a problem for me....and we get LOTS of snow
N1ck
Regina Sk
Yes, stock suspension. The spacers stick the wheels further out my .25mm this allows the tire to move away from the upper control arm.
BlackRamHemi
Upper control arm clearance with 12.2" wide tire on stock sport wheel (Terra Grappler)
Front sway bar clearance at full steering lock (passenger side , left turn)
Control Arm clearance is a little tighter with the new General Grabbers at 12.4" wide..
Not ALL 305 or 12.5" tires measure the same
Check with the manufacturers mounted measurements charts
Some are 11.6" wide, some are 13.6" wide
which may explain why "some" get rubbing and some do not. :favorites13:
Sybil
What would be a good street looking tire in this size? Looking to keep the street look vs the off-road look.
BlackRamHemi
Nitto 420s 305/50R20
(no good in snow though)
I plan to get a set of those for Summer,
as soon as I find another set of 14' sport wheels for $600 that will be powdercoated gloss black
Stock 275/60R20 vs 305/50R20 420s
Rherman1
Sunny Florida
6.7 Cummings
Who makes those wheels, I like them!
mtlariviere
Just put on a set of kelly tsr 285/70/17
