Official Redline SI-1 thread.
Zoe Saldana
california
6.4l
I went crazy with SI. 1 bottle(15 oz) EVERY fill up and have gone through about 20 bottles so far. Never skip a bottle when filling up gas. Also always use Shell 93 V-Power Nitro. The vehicle is at 245,000 miles now and the engine has been an issue with oil consumption since it was brand new. It is safe for CATS and O2 sensors.
Jim,
You should fill in your truck profile.
What year and engine do you have?
"Oil consumption since new" what is the cause?
Army
Jim came over from mdxers because we posted his incredible test, post 1 here bottom si-1 versus techron.
Jimhow4545
Boston
No
No
Jim,
I don’t own RAM truck. Bad engine design with low tension piston rings. 2010-2013 Acura MDX has this flaw engine design which is well known in the Acura community and Honda Acura Corp.
Army
If you look closely at these two photos you can see that S1 is melting or vaporizing carbon buildup layer by layers.
Are you thinking about trying redlines service chem? Is the throttle body easy to expose on that engine? I never assume anymore with crazy engine designs out there. You can shoot the can there from drivers seat with 8 ft tube. That will put xylene full strength right on the carbon. Come to think about it as much as you pull plugs, you can spray through plug hole, I'd just not over spray a little goes a long way, wouldn't want to flood it.
Army
I have to rewatch this, how he was able to keep fluid above rings and what he was able to do with turkey baster...
