Oil Filter Thread
mdc1990zr1
Conshohocken, PA
Well, I guess I have about 6 years worth of filters so there's no sense in trying to research all over again. Now I'd be inclined to look at Donaldson, PPE, and Baldwin if the need arose now
I've use Baldwin in the past. They seemed to be of quality construction but I only remember them being cellulose (paper) filters. I believe they are the OEM of Ferrari. That should speak for itself as to quality.
Burla
Burla
2010 Hemi Reg Cab 4x4
machinelube says it is easy to find this test, cowards didn't post brands but they say its out there, just google “SAE J1858” . That should be interesting
Rustypipes12
Buffalo, NY 14207
2009 TRX4 and 2024 BIGHORN 2500HD
5.7 hemi and 6.4 HEMI
I use Baldwin for my tractor for oil and hydraulics. It's interesting that I found cross reference to WIX filters for diesel and hydraulic. I didn't know they had those.
Rustypipes12
Buffalo, NY 14207
So member adrianp89 brought this test to the Syn thread, but this test is good enough to have it's own thread and many guys have tuned out of the Syn thread. This test proves the benefit from spun micro glass filters, all of the top three performers where spun microglass, and others such as Wix XP weren't tested. Anyhow, spun micro glass not only filters better out of the gate, but lasts much longer and holds contamination better. The top three filters tested in order are Royal Purple, Amsoil EA and Fram Ultra in third and the most economical choice. The test shows a different name for the third place filter, but it was changed to Ultra that year 2011. Below is the test filter after it passed through the tested filter (the name of the filters on the left), this is a compilation of the filters and as you can tell no noticeable contamination 30microns pass through the royal purple filter. Very little passed through the Amsoil or Fram Ultra. Read through the test page to see all of the results. Bottom line, Cellulose filters simply do not filter as good as synthetic media at any point in your oil change interval.
Okay, I'm missing something, don't see anything readable here.
Burla
Burla
It was the GM central oil filter study that is now 15 years later and I believe was taken down from the net, but it was up for a decade or better. You can still see the patches, which is a patch behind the tested media for what came through. As the top filters are no longer being produced, all we can take it the knowledge that shows how much better spun glass is, top 3 choices (rp-amsoil-fram ultra) were spun glass and 4th choice was blend with spun glass. This study also matches oil filter testing from a lab. Spun glass cannot be beat with paper, perhaps poly's can match it, but at the time those weren't tested.
Travis8352
Houghton michigan
That was back when amsoil filters used donaldsons synteq media. Nowdays amsoil says it uses a "proprietary synthetic media".
Rob2gen
Missouri
Mopar Magnum 360
I'm a Balwin user as well (B2 - holds an extra .5 qts) for my 2001 Ram with 360 Magnum. Buy them by the dozen on Amazon.
RidgeRunner_167
Southeast
According to bitog folks, the Mobil one filers made in viet nam are great quality. The actual filtering specs are a bit lacking. 30 microns at ? Percent.
South Korea.
Most of us suspect the new M1’s are made by VAFI, probably the same people who make the excellent Pentius PLXL filters. HW simply markets them.
RidgeRunner_167
Southeast
I'm tired of stressing about oil filters, then making a decision, only to find out after one or two uses, the filter composition totally changes and is not the filter it once was.
I've decided to go with STP Extended Life in the gold package. The specs look good, the pleats look better than the Fram I've been using, they are available less than two miles from my house, and cheaper priced.
I only run my oil 6k anyway, and oil samples look good.
I've decided I have too many other things to stress about. I will still stress some about the filters, but not near as much as before. Both the 3.6 and 5.7 engines are either going to last, or eat up the cams, no matter what filter is in it.
The new STP XLs are a PGI product. Excellent filters, and they are not significantly different than than the MSLs from O’Reilly or the CQPs from Advance.
Different Drummer
North East
Pentastar V6
Hep me out and let me be lazy folks.
No availability of the FE 1165 Synthetic Endurance ( V6 Pentastar). However I can grab a few XG 1165 Ultra Synthetic for the V6. Seems as though I remember somewhere back in this thread that the XG series ( 20,000 mile ) was a decent filter. No way I would go that many miles on a filter but I might do 10,000 miles.
I am thinking of grabbing a few of the XG Ultra synthetic series.
Please offer up your thoughts.
HEMIMANN
Minneapolis, MN
2017 2500 Laramie Crew Cab
6.4L HEMI
Yeah, this whole thing sucks, doesn't it.
XG was Fram's top filter, all synthetic. They then introduced a "new" filter they called "Endurance" with prefix "FE". FE is the old XG. Just to make things confusing so as to probably trick people, they kept the XG filters but degraded them down to a synthetic blend. So inventory leftover XG isn't "bad", it's just not best.
Hope that helps.
Travis8352
Houghton michigan
Hope that helps.
Old XG is better than new XG. Old XG had wire backed synthetic media and had a huge filter element compared to other top filters. The ascent filtration test showed it to be the best. Then they switched and the description was quite confusing. Frams website said it was a dual layed synthetic media but then another part of the site said dual layered synthetic blend media. But a few folks called them maybe you did to and they said no its fully synthetic. Either way they claimed better efficiency than the old XG. I still got 2 XG2s for the ram. But the old and new XGs were unique to fram filters and the FE came when first brands bought champion labs. They then just cloned the amsoil eaO and royal purple filters and called them fram synthetic endurance. And now its all going bye bye since first brands tried to grow the business by buying up other brands
Different Drummer
North East
Pentastar V6
Well, I have no idea how to tell an old XG from a new XG by looking at the box. Plus, being an entirely different design of filter for the Pentastar ( cartridge vs spin on ) I suppose that could come into play as well. I can see that they are made in Mexico.
From what you guys are saying the XG series is a decent filter so I guess I should grab a few while they are available. I was using the FE series but do not have any left on hand.
Travis8352
Houghton michigan
I would grab a few while you can. Ive never handled a cartridge filter honestly but id imagine its easy to feel if its wire backed. Even if its not the efficiency is fantastic maybe even better than the old XG. Maybe once you use those up we will be clear eyed on the filter future
Travis8352
Houghton michigan
I checked out a new highline warren mobil 1 filter today. They look fantastic in terms of quality. 99% at 30 microns. Top of filter is wrapped in plastic, made in south korea, holes in center tube instead of louvers
