Oil Filter Thread
huntergreen
Marine Corps Navy Badge
Me too, but I hate to change a 20000 mile filter at 6000 miles if I don't have to. It only holds about a pint of oil so I don't think its a problem like the old large filters, and the syn media should hold up.
I never run oil or filters to the max limits. I like a a margin of error on the safe side. I do know I am out of step on new oils and filters though.
Burla
Burla
Army
2010 Hemi Reg Cab 4x4
Quick question, I do about 5-6000 miles a year. Using PUP 5w20 and Fram ultra filter. OCI of up to 10000 miles according to manual, I don't want to leave the oil in for 2 years, but what about the filter, 2 years ok?
It is likely ok, but these hemi's benefit from being clean with the lifters and cams. Just for fun I tested full synthetic royal purple for 2 years it was like new. First I tested one for 14 months, that gave me confidence to go to 2 years. But Fram Ultra seam a little stiffer, so I'm not sure about those. But I call tell you for a matter of fact those royal purple filters held up to a 2 year/10k mile oci.
800steve
This is what I am talking about, I would be changing the 20000 mile filter at 10000 miles. As for leaving old oil in the filter, it only holds maybe a pint of oil, I am sure that more old oil is left in nooks and crannies in the engine after it is drained than that.
R.L.K.
Bristol , Tn.
I'd be much more concerned about using a 20wt oil for 10k
Burla
Burla
Army
20 weight is a pretty stable oil, it likely wont shear, but I worry about using 20 weight oil in general. I wonder how many of those cam fails are happening on the 5w30 crowd. And something to consider that many people are talking about is adding a qrt or two of heavier oil just for a little more protection, or looking at a top tier 0w30. I know with much confidence Amsoil EA filters and Royal Purple filters will outlast any oci. Anything else, you guys need to do the work on, my guess would be wix xp would be right there as well, for some reason I think Fram Ultra is a question mark, just because it starts so stiff. It may even outlast a RP filter, but I just don't know, someone should cut it open at a 2 year OCI like I did with the RP filter, that will be a great benefit to the thread whoever does it.
800steve
I am talking about changing the oil at 5-6000 once a year and changing the the filter at 10000 once every 2 years. I don't like the idea of running any oil 2 years.
gixxer
SK Canada
4.7L
You could just buy a cheap filter and change every year. Oil filters aren’t that much in the grand scheme.
HammerHead
USMC 0313
Georgia/Florida
2019 4Runner
I agree; not necessarily a cheep oil filter but even a quality synthetic oil filter will run you less than $15 bucks. That's once a year is not much imo.
KevinInVT
Graniteville
V6
I used a Fram ultra for my first change in my pentastar engine. They had the best filtration rating, full synthetic material, readily available and the best price Although I see amsoil started offering a filter recently that I may try. I'll post up some pics of the Fram when I remove it.
seabrook
seabrook
Black 2018 Night
5.7 3.92 anti slip
I always change the filter- I use the kn like the nut on it! I wish they had the same setup as the wrangler- filter is on the top of the motor
Burla
Burla
Army
Has anyone tried the Pennzoil Platinum HE filter?
Thanks for bringing it up, I never heard of this before. Look like a synthetic blended filter, likely similar to m1 in performance.
Pennzoil Platinum HE™ oil filters are engineered with an exclusive synthetic-blended 2-ply gradient density filter media designed to remove 99% of engine oil impurities while trapping on average over 10 grams of contaminants based on industry tests. This provides an average 15% greater cleaning ability, and over 3 times the dirt-holding capacity of economy oil filters.
Product Technical benefits:
  • Silicone anti-drain back valve lasts up to 2X longer than conventional nitrile valve to protect against dry starts
  • Keeps oil cleaner than standard oil filters for superior engine protection
  • PTFE impregnated NBR sealing gasket for ease of installation and removal
  • Steel spiral-wound center tube and end caps provide increased internal strength and durability compared to
    cardboard and plastic components
  • Meets or exceeds proposed industry specifications for capacity and efficiency
Hootbro
U.S. Army Veteran
Army
Delaware
2017 1500 Express 4x4
Pentastar 3.6L
^^^^ I'm curious as well. Not sure I've ever seen it for sale anywhere.
I have seen spotty availability of them on Amazon. My understanding is they are just a contract relabeled Purolator Boss filter.
dhill3
