- Joined
- Apr 28, 2012
- Posts
- 23,417
- Reaction score
- 45,407
- Ram Year
- 2010 Hemi Reg Cab 4x4
- Engine
- Hemi
None that I can think of, if they don't leak they don't leak.
I have used the boss filter before, no issues. I change oil and filter around 5-7k miles. I still prefer Wix....I've done multiple UOAs with Wix filters across multiple vehicles and have not seen issues with them.So, my truck finally hit 5k and change the oil with 4qt's RL 5-30 and 3qt's of RL 5-20 and this time went with the new Fram Titanium filter with the elongated holes. Truck is pretty noisy on start up and quiets right down. My first OCI was the same oil combo but with a WIX XP. I moved away from WIX due to the low efficiency rating but if it keeps the truck quiet, what the hell right. Anyone using the Purolator Boss?
I've never had any issues with WIX XP's in the past. Saw the Titanium at Auto Zone and figured what the hell. Probably just going to run with RP and get the best of both worlds.it doesn't surprise me the thin wix xp 100% synthetic media is a quiet choice, and we know the spun microglass filter media outlasts any oil. I do prefer the thicker looser rp filters, but if for some reason my rp was ticking, I'd go straight to wix xp as a choice. My hemi has proven some filters make it tick and others don't, same oil. I'd never accept engine tick if all I have to do is change the filter, I care more about that then efficiency rating. The proof is in the recent long term ram forum members experience, his engine wasnt ticking on his combo but now ticks.
The bad part of the GM test was not having wix xp in the results to gauge the efficiency, those patches don't lie. The manufacturing of filters seams to be on shaky ground, we never know what is going away or what is going to change, I think wix xp has a place, might not be the "best" for all of the considerations tick and efficiency, but it seams to address one of those well, and maybe the other, we just don't know.
keep syn thread and redline thread updated, thanksI'm trying 0w-30 this winter because I had possibly piston slap last winter, I will get the 20-820 and cross my fingers then.
Totally not worried about the dry tick, it's only happened twice but if even that can be eliminated then all the better.
I personally am interested if 20-820 would fix this, it might.I had it with both 5w-30 and 5w-20. They still sounded quiet in the winter when hot (though the 30w still sounded most quiet), it was just a low down knocking noise when engine was cold that I didn't like that I want to fix for this winter.
Yes, all of my 5.7 Liter HEMI engines from 2009 up to 2017 had this dry start for a second or so ... no HEMI tick or piston slap ... so, I justified my oil and filter strategy by reading these oil/filter threads and recently made the switch to Red Line 5w/30 from the off the shelf Pennzoil Platinum crap that I've worshiped as the most best oil for my HEMI engines ... well, my current 5.7 Liter HEMI is just a very little over 39, 000 miles on Red Line 5w/30 and my valve train noise was reduced to non existent ... there isn't any dry start up anymore and I should have used Red Line all along ... I'm not turning back ... I will be easing up on the winter months coming up and use 0w/30 ... yep, all is good ...Redline 5w-30. I switched to RL because I read that it can quiet the engine, and it does. By "quiet", I don't just mean "hemi tick", I mean the entire engine just sounds quieter/smoother when it's idling or running. I ran RL 5w-20 on same familter last OC, I believe it was slightly noiser than current 5w-30, and since I tow in the spring/summer/fall months I wanted something thicker than the watery 5w-20.
So again, I don't think this is "hemi tick", this is just a dry startup tick. About 1 to 2 seconds of nasty ticking noise immediately after engine catches when it starts, and then suddenly instantly it's gone. I've watched enough videos to where I'm sure I can distinguish between "dry startup tick" and "hemi tick", and I don't believe I have the actual hemi tick problem.
To me it sounds like an oil filter problem, (maybe a bad ADV) not an oil problem, but I'm far from an expert.
