HEMIMANN
- Joined
- Dec 7, 2020
- Posts
- 9,514
- Reaction score
- 25,094
- Location
- Minneapolis, MN
- Ram Year
- 2017 2500 Laramie Crew Cab
- Engine
- 6.4L HEMI
Ah, $hit - forgot about the expensive part - the unlocked PCM.You'll need an unlocked pcm / bypass cable and tuner to bump your idle rpm up. It's not exactly cheap to bump the idle rpm up on the 15+ trucks. Unless you plan on tuning the truck,it's hard to justify the costs involved to just bump the idle up
Sorry BOIRD.
Yeah, so like Rick says, us po' boys (in my case I'd already tuned before I knew about this) do stuff like look for lower restriction media oil filters, and pre-lube the engine before starting if it's sat awhile. Push gas pedal to floor, foot on brake, and crank. Engine will crank without firing, so you build up oil pressure in galleys @ starter rpm ~ 200 rpm without the firing loads of engine running, and engine starting going instantly to 1,400 rpm warm up mode.
To stop the cranking you take foot off brake and push start button again. I do a few of these pre-lube cycles prior to starting engine. Also, on shut down, rev the engine or hold ~ 1,000 rpm when turning engine off. Keeps oil galleys full. Don't know how fast they drain down. Again, if you start every day, shutting down @ higher rpm should be fine. If not running every day, then I do the pre-lube cycles first.
Hope this helps.
