Oil leak
Matthew Smith
Georgia
I have a oil leak I believe it’s coming from the oil pan near where it meets the tranny. How difficult is it to drop the oil pan my self
Bummer
huntergreen
Marine Corps Navy Badge
If a sealant can stop a leak what else can it stop ? Best move is to fix it correctly.
jws123
nj
It’s the 5.7
I dropped the pan on my 2011 5.7 same mileage. Its not to bad But ya gotta un bolt the front axle from the mount and jack the truck up to make space for pan to come out.
Unless yours is 2wd that would make it a lot easier.
Matthew Smith
Matthew Smith
Georgia
It is 2wd but is the gasket easy to remove I’ve been told on the older ones you had to take off the oil sump or something
jws123
nj
Being 2wd should be easy to replace once the pan is off you remove the oil pickup tube with 2 bolts then pull gasket off not hard at all make sure to replace the o ring where oil pump and pickup tube meet.
PoMansRam
East Aurora NY
Maybe I'm not interpreting the pics correctly, but that doesn't look like a pan leak to me. It may be coming from above, like a valve cover gasket leak, etc.
Docwagon1776
Midwest
I was getting ready to post the same thing. From the pic it looks like oil is coming down from above.
eddie046
With those miles could be a rear crankshaft seal too.
NealS
Nine Mile Falls WA
2019 RAM 1500 Limited w/ RAMBoxs
5.7-Liter V8 HEMI® MDS VVT Engine
Hope it's only the pan gasket, or other minor repair. My 2019 developed a leak in it's first thousand miles. It turned out to be the main seal. Took two days at a dealers to pull the crank down and replace the seal. I hope you've already resolved it.
Hardracer
Swfl
2010 1500 laramie 4x4 crew cab
I was thinkin rear seal also..anytime I see a leak in that area thats usually what I'm thinkin....hope not tho.. PIA job to fix.
