ReekingHavoc
Oklahoma
5.7L
I recently had an oil change 5w-20 and filter changed on my 2019 Ram 1500 5.7L. When I start the truck it displays 0 psi for then jumps to around 55-60 psi within seconds. Drove around the block about a mile and a half turned off the truck and the psi drops to 0. I’m monitoring this through the dash setting that show oil temp and psi. Temp I believe is around 120ish.
I’m wondering if this is normal? I’m not sure if the truck had 5w-30 in it previously as the sticker on the window indicates but I went with what was on the oil cap on the engine.
Truck is not making any noise or displaying and lights on the dash.
Oil level looks good on the dip stick.
Thanks for any advise, I don’t want to jack anything up in this truck.
Daniel Ortiz
Houston, TX
5.7 L Hemi V8
@ReekingHavoc , the engine has to turn to make the oil pump work, and it takes a second or two for the oil pump to develop the pressure up to the full amount at start-up (mid to high 50s, as you said). That's why most engine wear comes from cold start-ups, before the oil has had a chance to work its way up with meaningful pressure. During those 1 to 2 seconds it takes, the moving parts rely on residual oil film from the last shut-down. That's another reason it's not good to let a car sit too long without turning it on and warming it up. This is normal, if unfortunate. An electric primer motor would be an interesting invention, but probably overly-complicated, and perhaps un-necessary.
Now, if it takes TOO long to develop the pressure and you start hearing the clacking of lifters on the camshaft, that is less than ideal, but does occasionally occur to some of us (me included occasionally). But if you don't hear any lifters clacking at start up, and only see your pressure shoot up from zero, that is normal, and what happens in my truck as well.
danielmid
Southeast WI
2015 Sport 4x4
Likely filter related draindown, and 5w-30 performs better in the Hemis than the 5w-20 usually.
turkeybird56
Central Texas
YUP, sounds like drain down, from filter, why U see recommended on Oil/Filter thread at a Minimum purchase good quality filter. A lot of us run a RP Filter or 100% Synthetic Fram Filter, or something similar with good pressure drain back valves. I run 5W20, but my truck is a driveway princess. If run a lot, would run 5W30. And I run full synthetic with a full synthetic filter. Another train of thought is to rev engine a few times before U shut down. Not sure on that one. But on my 2019 DT, rarely get cold start/clatter especially since I went from OEM to Fram. Now this is all IMHO... OP (original poster), Check out the Oil and Oil Filter thread by Burla and make an informed decision.
R
ReekingHavoc
Oklahoma
5.7L
Right now it I’m using a mopar mp-330 filter, I’m definitely checking out that filter thread. Thank you.
R
ReekingHavoc
Oklahoma
5.7L
That makes sense, it only take about 1-2 seconds to get up to mid 50 psi but I don’t remember it dropping the pressure to 0 after the truck was turned off before the oil change.
Accusump/Canton has been building pressure lubers for years,and they do have an electric version now,the older ones used to store oil pressurized by the oil pump,and would release it when ever oil pressure dropped.The older ones used a manual shut off valve,that you closed when you shut the engine off,either by cable or by hand,then you opened the valve just prior to start-up,to pressurize the oil system.They were big in the road racing world,then the drag guys found them,and followed suit.
Daniel Ortiz
Houston, TX
5.7 L Hemi V8
@ReekingHavoc , if the engine isn't turning neither is the oil pump, and I can only assume the pressure zips down to zero as soon as physics allows. Besides, still engines don't need much oil pressure. :)
The reason many Hemi owners use 5W-30 is for better wear resistance at operating temperatures (that's the 30 part of the 5W-30). But note that at cold startup, 5W-30 will behave the same as 5W-20 (that's the 5W part). So, at least in terms of cold-start oil pressure, you needn't worry about the difference.
But as the gents above mention (and in the threads they reference), 5W-30 is used by MANY Hemi owners without any problems, and is believed to have better wear properties for the lifters, which sometimes fail on these engines (dreaded Hemi tick, the bad one).
If you have a remote filter Daniel,they're easy to plumb in.I've thought of plumbing one in on my Transdapt set-up,as it has extra ports for such a accumulator or remote cooler,but that's as far as i've got,lol
