jeffhoward001
I tried to post in the V6 sub-forum, but it said I didn't have permission...
I have a V6 Durango, but some of the guys on that forum told me the RAM forum would probably be a better resource for V6 towing questions.
We have probably 4000 towing miles with a 3500 lbs trailer (fully loaded). I didn't notice until just recently that the oil temp was peaking 280 degrees over a mountain pass. Outside air temp was in the 80's.
My questions are: 1) Is 280-degree oil "normal" for towing with the Pentastar? I use a synthetic blend, but that still seems way too hot.
2) I'm surprised we didn't notice this before. I only noticed it this time because we got a CEL going over the pass. Had it scanned and it was a "cam position sensor signal intermittent" code. We didn't see it again until later in the trip when it was hot on a hill again, like clockwork at 275-280 degrees it threw the CEL. That scared me enough to really let it cool down before & after the passes.
Anyway, otherwise the truck runs fine and tows fine. Plus, we did 3000 towing miles last season with no issues, so I'm pretty confused. Is the cam sensor that's on the way out? Or is the super hot oil causing it to malfunction? Any other dumb reasons I'm not thinking of that's making the oil run so hot?
If it werent for the wierd canless oil filter set up, a cheap $100 oil cooler would likely be a simple fix.
Thanks All,
Thanks All,
