Oil Weight Recommendation for SC Hemi?
Gamester
Hey guys,
What weight of synthetic oil do you guys recommend for a supercharged Hemi with 10,000 miles on it? I've heard mentionings on here of 0w-40 and 5w-30 so far, but not sure which would be better for my application.
Thanks
charonblk07
Calgary, Ab
F1-A forged 349ci
Xw20 or Xw30, there's no reason to go to a higher weight unless you're trying to fix a specific problem. I run 5w30 in mine because the MDS is removed and I had seepage issues that the higher weight cured which might have actually been a crankcase vacuum issue. For yours as a daily driver just stick with the 5w20 but use a good synthetic oil and quality filter and you'll be in good shape.
03MopaRamman
RAM SPORT / 18 SRT
Southern Alberta
2019 (2003 Forgottens SOLD and 2014 SOLD)
Hemi 5.7 (392 Hemi) 86 Ford .308 HO Roller
0w40 been running it since before Mopar 6.4s swapped to it which is a blessing and got me off the once only brand Rotella, now it's avail in Mobil one. Danny
Gamester
Gamester
I have MDS disabled as well, so I guess 5w30 would be good. I just don't want to go too thick to the point of causing issues.
Feli
I have mds disabled, but I use 5w20. Should I switch to 5w30?
charonblk07
Calgary, Ab
F1-A forged 349ci
There' a difference between disabled and physically removed. Unless you've swapped out the MDS lifters for the non-MDS lifters just stick with the 5w20.
Feli
alright thanks
SyN
6.7L CTD Owner
Tornado Alley
6.7L CTD
Gamester: I agree with Charon on the 30wt.
One thing to remember every 0W oil will be a {So Called} synthetic.
With you being INTO the pedal more then the normal daily driver. I would not advise a 20wt. It is fine for the daily driver driven civilized.
One thing I have noticed over they many years-->The 20wt oils have NEVER been proven {Acutal Proven Data} to provide BETTER or LOWER wear numbers compared to a 30wt or 40wt. Only some what better MPG numbers for the daily driver. Even the UOA within BITOG has proven this.
For the Daily Driver which is driven sensible & never pushed or worked hard-->The 20Wt is the perfect fit. JMHO!
RodRam
Ga.
MDS scare tactics by ram are ********, the mds will work perfect with 5-30 or even a 40, its been proven many times by guys running it many thousands of miles. So in a supper charged motor 5-30 will do fine just buy the best you can find.
