On Board Air
ramhunter9
P-Star Jeep Wrangler
Viair Xtreme Duty On Board Air Systems ..
VA10009
For use with Air Locking Differentials, Air Horns, Air Tools, Inflate Tires 37" & Larger
VIAIR’s X’treme Duty On-board Air System is a pre-packaged compressed air solution that provides two 350C, 100% duty cycle compressors, a 2.0 gallon air tank, inline pressure regulation, and all components needed to install a working system capable of inflating tires, managing air locking differentials, and more.
Included Parts:
- 2.0 Gallon VIAIR Air Tank
- (2) 350C VIAIR Compressors
- 30ft. Coil Hose w/ Quick Connects
- Tire Inflation Gun with 200 PSI Gauge
- 0-150 PSI Pressure Regulator
- Blow Gun Air Tool
- 1/4” NPT Quick Connect Coupler (F)
- Dash Panel Gauge with ON/OFF Switch
- Pressure Switch (110 PSI on, 150 PSI off)
- (2) 40-amp Relays
- Inline Fuse Holder w/ Fuse
- 1/4” NPT 175 PSI Safety Valve
- 1/4” NPT Drain ****
- (2) 1/8” BSP to 1/4” NPT (Air Locker Use)
- (5) 1/4” NPT Compression Fittings
- 4” Strip of Continuous Grommet Material
- 20ft. 12-Gauge Wire
- T-Fitting (1/4”(M) x 1/4”(F) x 1/8”(F))
- Electrical Connections
Specifications:
-12-Volt
-Permanent Magnetic Motor
-Duty Cycle: 100% @ 100 PSI
-Max. Working Pressure: 150 PSI
-Max. Amp Draw: 29 Amps
$550 FREE shipping to lower 48
Also have smaller duty ranging from $200 on up
ramhunter9
ramhunter9
ramhunter9
ramhunter9
x2!!!!!!!!!!!!!!!!!!!!!!!
Can this really support air tools(air impacts and the such)????
Seen it in person .. YES it can .. it is a bad ass setup
SmokedRam
Zephyrhills, Florida
There was a guy on another forum I am on that installs fence. The power in a neighborhood he was installing a privacy fence in went out before he could finish the final side of the fence. No problem...ran air hose from his on board air system and got the job finished.
BigDogg795
Ronkonkoma, NY
So I could use this for an air horn set up too, couldn't I?
Sent from my DROID RAZR using Tapatalk 2
ramhunter9
ramhunter9
Most definitely and run a tap to fill tires or air tools
schroederMP
Indiana
Cummins
Once I start building my trail rig I'll be hitting you up on one of these
reddot
Wolf Point, MT
5.9 cummins
Well Dave I hoped you saved my paypal addy. Ill take the kit. Send me the invoice or if you need my info shoot over a PM. Thanks.
I know Ryan. Think his is a custom setup. Pretty sure he has a 3gal tank at least.
ramhunter9
ramhunter9
Invoice sent Reece
BlackedOutHemi
DFW, Texas
2012 & 2012
5.7L HEMI & 6.7L Cummins
Hmm. I have an air tank and compressor, but his setup is much better looking and way more powerful. This may be tempting in the future.
ramhunter9
ramhunter9
Well Reece took advantage of this kit .. all set bud . Thanks... and o ya I will need pics of this bad as set up
reddot
Wolf Point, MT
5.9 cummins
payment sent. Thanks Dave, but if you can do me and my bank account a favor and stay out of my head it would be appreciated. Thanks. lol
Shoot me a tracking# when yah get it. Thanks.
Hope to have pics sooner the all the other mods sitting in the bed. lol...........oh I suck.
ramhunter9
ramhunter9
LOL . will do bud
ramhunter9
ramhunter9
Reece does not **** around .. he is one of my top customers
