One piece or two piece driveshaft?
sethcolby3
Magnum 4.7
Hi guys,
So I’m in the process of ordering the MaxTrac 7” lift kit, but one of the options is whether I have a one piece driveshaft or two piece. It looks like I need a carrier bearing spacer if I have a two piece driveshaft. I’m going to be honest, though, I have no idea which one I have, and I also don’t even know how to go about checking. So I was hoping you guys could point me in the right direction. The truck is a 2010 Ram 1500, 5.7L 2WD Crew Cab Short Bed.
Thank you in advance for your help
Hi guys,
Crawl under the truck and look at the driveshaft,it's pretty easy to see if it's a single shaft from the back of the transmission to the rearend,if it's a 2 piece shaft,it'll have a carrier bearing where the 2 shafts join.Best option is to usually look at your truck first,and if the obvious doesn't jump out at you,then go to social media. If you don't know what the driveshaft is,or how to check and see if it's a single shaft or a 2 piece shaft,are you sure you need a 7" lift.
One or two piece drive shafts can depend on length
drive shaft makers do not like to build 60" drive shafts, so they use a carrier bearing near the center
another reason for a 2 piece drive shaft has to do with U-joint angles, it is a bit complicated to explain
RedSRT4Me
Scottsdale, Az
2015 CC Sport
Hi guys,
Those specs should put you at the 140.x wheel base which I'm 99% sure you have a 2 piece drive shaft.
BolletuH
Wyoming
I think in most cases 2WDs usually have 2 piece driveshafts with a carrier bearing since you are missing the length extension of the transfer case. As stated before just take a quick peek under the truck and you will see either one or two driveshafts extending from the transmission to the rear differential.
brunzca
St Johns, Fl
Hemi 5.7 (non-Etorque)
Bumping this for help - I just had a 7” Maxtrac lift installed on my 2021 RWD Bighorn, I have a 2 pice driveshaft (quad cab, 6’4” bed). Do I need the carrier bolt spacer/drop kit? It wasn’t an option to order from Maxtrac for my model year, but I can order it for the older year (should fit mine) or order from Zone for my year.
I reached out to Maxtrac via email, they claim it’s not necessary for the 19 and newer model year. However…there is noticeably more vibration than pre install (when there was none), specifically between 52-58 mph, maybe this is what’s causing it?
**sorry wrong forum - will move to 5th gen
RedSRT4Me
Scottsdale, Az
2015 CC Sport
It will absolutely help your issue, but you will have to measure during installation. The kit provides 3 spacers on each bolt of the drop kit.
You might only need 1 or 2 spacers on each side vs the full 3.
Riverside California
2018 2wd
HEMI 5.7 Revolution 4.88s
I forgot to mention the 3 spacers ... but I am pretty sure he is going to need all 3 regardless ....
