DieselMike29
- Joined
- May 12, 2019
- Posts
- 33
- Reaction score
- 22
- Location
- Ladson, SC 29456-3111
- Ram Year
- 2015
- Engine
- EcoDiesel
I'd have to disagree with you on the heater not putting out any heat till the thermostat opens.The heater is actually tied in ahead of the thermostat on pretty well every vehicle built. Put your hand in front of the heater when the temp gauge is saying 130/140'ish,you'll feel heat coming from it,and the thermostat should not be open at those engine temps.BTW i'm in Alberta so I know cold too,lol. It's not wise to totally remove the T-stat unless you add a restrictor plate in it's place,full flow means the coolant is circulating to fast to actually absorb any heat from the engine block
Oh, I agree with what you said and have experienced that myself, but remember also that I said "the thermostat temperature is when FULL flow is allowed" Unless they have COMPLETELY changed how the cooling system on vehicles works since I played with them on my 1967 Chevelle SS396 (WHY OH WHY did I ever sell that car????), the heater hoses connect outside the circuit that allows the block to heat before opening to the radiator.
There are several little "tricks" I learned about the heating system (that part of the overall COOLING system for the vehicle) when I was much much younger.
First, how do you check to tell if the thermostat is "locked"/"frozen" shut? You grab the heater inlet hose - if it is cold when the engine is hot, the thermostat hasn't opened. (NOTE: "cold" and "hot" are relative terms in that 120 degrees is "cold" compared to "220" degrees.) This works because the heater supply (hot) connection is after the thermostat.
Second how to you check to see if the thermostat is "frozen" open? There are actually two ways, but by combining them you get a fairly accurate answer. They are: 1)put your hand on the radiator tank or (preferred method) upper inlet hose right after (within a minute of) starting the engine and/or 2) put a hand on the heater inlet hose. If the hoses warm up immediately and get hotter as the engine heats up, your thermostat is open. In this case, the thermostat could be partially open which would allow immediate flow to the radiator and the heater.
Why would you consider making those checks in the first place? The stuck shut thermostat is more easily noticed because the engine almost immediately overheats. It will take longer to notice that the engine is not heating to operating temperature as quickly as it should (because of a stuck open thermostat, but a loss of power or unresponsiveness should alert you to making the check.
Again, yes, you will feel some heat coming from the heater when the temperature in the engine has reached a certain temperature (how high depends on the (call it) full open temperature, ie the rated temperature of the thermostat).
And exactly why do you want the thermostat to open slowly and not pop wide open all at one time? The water in the cooling channels of the block is a fairly small part of the total amount of water in the entire cooling system. The radiator, on the other hand, contains MOST of the water (Okay, okay - it is "coolant" and NOT pure water) in the cooling system. (The heater actually contains quite a bit of the water too.)
If the thermostat were to pop wide open you would introduce that (relatively) LARGE amount of much colder water from the radiator into the hot block or the engine. Such a happening would cause (if not all at once, over time) a brittle fracture of the block - the walls of the cooling channels are quite thin in places and VERY susceptible to brittle fracture. To prevent this from happening, the thermostat is designed to open slowly to allow the water in the radiator to heat up as it starts to flow into the block.
