P0456 code
Tom8
Utah
Started my 2014 1500 and got a check engine light. Have jiffy line out an obd reader and found that it has p0456. Truck has 72k. Replaced the gas cap to see if this happens again. Anyone had this issue and what were your fix?
burner71
plano, tx
So I would get the gas cap light every other week and the code now and then. Finally my gas cap light would not go out. I bought a new purge solenoid at oreilys for like 14 bucks.
On my truck it’s under the battery, on others it’s on the intake manifold. Swapped it out, took about 5 minutes. No more light or code for the past few weeks.
T
Tom8
Utah
I think that is my second thing I will swap out if it comes back again. Did your light go out by itself after fixing it or did you have to reset it with the OND reader?
T
Tom8
Utah
It went out right away.
I have a 2014 1500 and didn't get a gas light but rather a check engine light; when put to the OBD reader is shows P0456. Did your check engine light also go out without having to reset it?
burner71
plano, tx
i have a diablo tuner so when i would get the light i would clear it. It was not on when i changed the purge valve so im not sure if it would have gone off right away or after about 50-80 miles of driving.
T
Tom8
Utah
So your 2012 ram have a gas cap light? interesting.... thanks for the info!
Hanover Fiste
Air Force
NW Florida
2005 SLT, 2018 Sport
I have the same code in my '05. I've replaced every component in the system except for the tubing (which is no longer available), and I still get the code. I just reset it now instead of throwing more money at it.
T
Tom8
Utah
Bring it in for a smoke test or if you have a pump, connect it and see if the pressure drops. If it does then you know it’s from the line somewhere. I heard your year, the line above the gas tank where the ventilator pump sites can rupture at the end. There was a guy who did a YouTube video of it.
T
Tom8
Utah
Visually checked all the lines and no cracks. So replaced both the gas cap and the purge valve. See if this annoying cold will come back before attempted to change the other module on top of the gas tank. I suspect it’s the purge valve.
Cwils80
Knoxville
Second that on a purge seloniod here. No gas cap light just the code. My was just under the engine cover. Aswell just 10 minutes to replace and light went off and never came back.
