P0481 Error - Elusive Cooling Fan Relay 2 Location
Brian8563
WISCONSIN
Where is this relay located on a 2016 Ram 1500 with a 5.7? Thanks!
B
Brian8563
WISCONSIN
It has been suggested that it is in the power distribution center F01. F01 is position is empty.
B
Brian8563
WISCONSIN
It has been suggested that it is near the horn. Nope, just the horn there. No relay.
B
Brian8563
WISCONSIN
Underneath the power distribution center? Not literally and I did not see any obvious relay in the area...
B
Brian8563
WISCONSIN
Perhaps that meant - under the fuse board in the power distribution center... A swing and a miss as far as I can tell.2019-08-12-19-34-46.jpg 2019-08-12-19-35-27.jpg IMG_20190812_192821534.jpg
Tach_tech
5.7L HEMI
Did you install a relay into the high position?
B
Brian8563
WISCONSIN
I did not and was not planning to. As far as I know it has never been populated. Should I install one?
Tach_tech
5.7L HEMI
I would install a relay. That is the correct location for the high speed relay, and it’s missing.
Tach_tech
5.7L HEMI
How did the relay jump ship?
You’d be surprised. A few times I’ve worked on vehicles for a CEL or whatever, only to find a missing fuse.
Just a few months ago I worked on a 3500 that was towed in for a no start. Customer said he was driving and it just shut off and wouldn’t start. I found the fuel pump fuse was missing. Put a fuse in it and good to go.
chrisbh17
Thats scary!
B
Brian8563
WISCONSIN
I agree! Can someone tell me if it is the same part as the low speed relay?
Ilo670
