Panic/security horn
Pines19
Iowa
I need this disabled now. I’m sick of it going off for no d_mn reason. I don’t know if I’m triggering it or what, but it goes off when you least expect it.
How do I turn this off for good.
2018 Big Horn.
Ghost_RAM
VA
If you're referring to the VTA then it can be accomplished in AlfaOBD by disabling the setting. I'm assuming you're referring to the fob in which case I'm sure you could mod the fob by removing the little disc behind the panic button that makes contact with the board.
Jimmy07
2018 Big Horn.
If you have the same problem as I had, when I insert the fob into the ignition, and if it didn’t go straight in, it would bump the panic button. So I took the rubber overlay off the fob and removed the little plastic contact disc underneath the panic button.
Ghost_RAM
VA
As fumbly as I am with this I have yet to have this happen. Glad too, I'd probably crap myself not expecting it.. lol
