- Joined
- Apr 28, 2012
- Posts
- 27,543
- Reaction score
- 57,754
- Ram Year
- 2010 Hemi Reg Cab 4x4
- Engine
- Hemi
Is there a Moly additive that can be added?
Lubegard biotech
5W-20 or the Prefered 5w-30 Redline oil.I am looking at Amazon right now for redline. Do you use the 5w20 in the red 1 gallon jug? When I click on it it asks what vehicle I have, when I enter my vehicle info it says not for your vehicle? As for the royal purple filter what is the part number for a 2012 ram bighorn 5.7?
DailyRam: By looking into your signature I see you possibly still have the Stock Exhaust System in place?
Lubegard biotech
I prefer the oil soluble moly technology in lubegard's biotech, as opposed to powdered moly in suspension like liqui moly.
Just run the 30wt oil ....I've ran a 40wt and had ZERO issues with the MDS system ! ! !Most guys (me included) in oil thread are running 5w30 with no issues, some guys even are closer to 40 weight. The benefit is more film strength. I'm in the middle of a 7 year test to see if it actually translates to better wear numbers, but we don't have that answer yet. 5w20 is acceptable, if you feel comfortable running that, so far the data backs that up and a reasonable thing to do.
Wow !So here is the run down. I took mine in for what I thought was 1-2 broken bolts on passenger side. That was the ticking side. When I picked up the truck today (I will eat my earlier words, they got it done in one day) they had replaced both manifolds for being warped and there were 3 broken bolts on the left side and 2 on the right.
No indication was offered as to what is causing this. I am only at 50ish thousand miles, so plenty of time to take it in again and have the work redone if needed.
One of the bolts had to be subbed out to a mobile machine shop because the usual Chrysler Techs couldn't get it out.
I will give them props for getting it done and being very polite about it all.
