payload
millhunky
swpa
Hey guys looking to haul some gravel for a french drain this week. I think i remember seeing around 3200 lbs for payload for a 2500 cc short box . Does that seem about right. And if anyone has haul gravel how much does that represent on the bed. Like half full.
Thanks mark
WaterBoy1
Ontario
2014 Laramie CC2500 Black Edition
Better check the door sticker for your actual payload rating. They seem to vary quite a bit depending on options etc.
My CC 2500 is around 3100lbs
regularcab2500
Buffalo
5.9 Magnum
The yellow-ish sticker with your max cargo rating including passengers should be just under the door jamb on the cab. I have a pretty loaded up rc (well loaded for a 2 door lol) and my sticker says 3418. I would say 1 ton of standard gravel will pretty well fill the bed though.
M
millhunky
swpa
Ok thanks i brought it to,work tonight i will check when i,get done
Thanks
bighorn2500
2015 2500 ram bighorn
6.4 hemi
I picked up some 57 stone at the local quarry one scoop was right at 8000 pounds. Gravel does terrible things to bed liner borrow a trailer if you can.
6.4 dude
Oklahoma
6.4 hemi
^what he said. I wouldn't do it. Borrow a trailer or have it trucked in.
M
millhunky
swpa
I would but i have a narrow driveway no dual wheel dump will fit up it.
mowin
upstate ny
2017 3500 SRW
6.4 hemi
Put a piece of plywood down first. It will protect your bed. A yrd of stone/gravel will weigh around 2500-3000#.
M
millhunky
swpa
Well got my first 2 loads today. 3010 one load. 3560 other truck did well only 2 mile hual. Getting rest on Saturday. I try to post a pic later but i was really impressed on how much it didnt sag
Thanks mark
regularcab2500
Buffalo
5.9 Magnum
Wow that is pretty impressive, its still sitting pretty level.
WaterBoy1
Ontario
Wow that is impressive! Is that a pic with the 3100 or 3500 lb load?
Either way, these trucks are obviously pretty stout!
Jaxyaks
They are pretty impressive, I had a small pallet of concrete estimated around 3k on mine and while it squatted a little, you hardly felt it in the drivers seat
mtofell
You guys are killing me!!!!! :) :)
No gravel in the bed of a PICK UP. I'm going to start revoking man cards here in a minute.
I use to throw down a tarp on my old truck when I hauled gravel because it was a PITA when it got stuck under the 5th wheel rails. A piece of plywood couldn't hurt I suppose.
