Power locks help!
KLayton
5.9 Cummins
Hi I'm new to the forum. I have searched all over and still can not find an answer.
I have a 2002 2500, my power locks will not work with either switch however when I turn the ignition off or on it will unlock the doors. Also when I use keyless entry they both work as well... Any ideas?!?
dudeman2009
2001 1500 Sport with enough electrical modifications to make my brain hurt
Magnum 360
If the ignition has a direct effect on the power locks, I would suspect a bad CTM. I'm interpreting what you said as, turning the ignition on either locks or unlocks the doors, turning it back off, also either locks or unlocks the doors. That spells bad CTM to me.
K
KLayton
5.9 Cummins
Yes that is correct. What the heck is a CTM?
dudeman2009
Magnum 360
Central Timer Module. its one of the computers in the vehicle.
