Power running boards
Pull Ya
Cedar Creek, Tx
He left em down ... Not the car wash’s fault ... That’s also why they tell you to take your antenna off ... Can’t blame somebody else for your mistake
Your right but people still try to do it every day. (This is not directed at the OP)
Jay
F
fred123467
texas
v8
I have amp on my truck and those are not it. They look like they are the bestop brand, probably the 75138-15
Definitely not amp. Definitely a factory button. Contacted amp and they do not manufacture the factory ram boards for this model. Not the car washes fauly, never said it was. It was mine. As stated above I'm trying to find a more cost efficient solution.
I'll try contacting Boston next
DodgeDude99
Oak Lawn, Illinois
Those aren’t Bestops, at least their arms look nothing like that. Here’s a bestop arm.
Their website only shows up to 2018.
Bliksimstraal
Houston
Fred123467, please let me know when you find out where they come from. Exact same thing happened to my limited. Only, I did not set mine down manually. Only the one side was down for some reason (saw in the car wash video footage). The side that was down was caught up in the washer.
Agreed, very expensive replacement. I have been waiting 3 months already to see if MOPAR will produce a "sub-assembly" for the $1500 replacement.
IowaRick
Council Bluffs Iowa
ecodeisel
Check with your local computer nerds I bet the part could be 3D printed a whole lot cheaper. Set up a run and sell extras on eBay and recover your cost.
kp4243
NC
Agreed Mopar didn't manufacture them.
Bliksimstraal
Houston
Just reviving this thread to find out if anyone has had any luck? I have tried a few local metal fabrication companies. None baring one has even bothered to reply to my quote requests. I even took the time to do a technical drawing of the brackets so that folks could see what the dimensions are.
BOWERSFJ
Uniontown OH
A good machine shop can’t charge enough to make it worth their while, and still be affordable for you ... Material minimums, programming and machine setup time ... It’s just not worth it for them
bigdodge
Looking at the RBP steps they look pretty similar to what the Mopar steps are. Someone makes them.
MotorBoy
Ontario
Hemi 6.1
It's hard to say. Your running board looks really a bulk.
Reticle918
