Power Steering return hose, 2014 2500 6.4L gas
Paperboy4828
Upstate, NY
I've looked all over for this hose. The dealer has also looked. Part Number 68031850AG or 68031850AH... Any ideas? Can one be custom fabricated?
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
Might be able to get away with marine grade fuel line?
Edit: somebody chime in if fuel lines are a no no with power steering.
04fxdwgi
Coastal NE North Carolina
2016 1500 Sport
Marine grade A1 fuel line must be made of some material only found mining on Mars since it so expensive (I know, replaced it all on my boat).
The 2 hour fire rating A1 is not needed on a road vehicle and way overkill. Any oil resistant hose will work on the no pressure return. The supply line must be high pressure rated and oil resistant..
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
If i am not mistaken, fuel line hose is made extra sturdy, it can withstand suction, without collapsing, but are they large enough in diameter ?
Summit reports part is unavailable
Google Search brings up these possibilities
  • Genuine:
  • SKU:68031851aj
  • Description:
    POWER STEERING RETURN
  • Condition:New
  • Replaces:68031851AD, 68031851AE, 68031851AF, 68031851AG, 68031851AH
RockAuto is out of stock
If you have the damaged part in your possession
these people deal with Hydraulic Hoses & fittings
call https://www.omniservices.com/store-locations/
there are several locations in New York
another Hose company
I used to operate heavy equipment, Back Hoes, Motor Graders, Skip & Front Loaders, etc. blows a line
Sooner or later equipment Hydraulic lines blow, both pressurized and non pressurized.
With heavy equipment, you can't go to the local HOSE Pros, so they drive out to the construction site & make a new hose onsite.
I meant to type this up about 8 hours ago, but my nurse made me get back to bed & sleep.
Good Luck
Paperboy4828
Paperboy4828
Upstate, NY
  • Genuine:
  • SKU:68031851aj
  • Description:
  • Condition:New
Good Luck
Thanks, I also have had hydraulic lines made for tractors and my backhoe. The guys that normally do that (Nx Wxx Hydraulic) won't because the "heat" possible from the pressure side line on the power steering, and possible liability from a failure. I think its a cop-out, my tractor and backhoe hydraulics get plenty hot when really working them. Anyway, I think the Omniservices.com will be the next stop, once I have the hoses in hand.
I also had the part numbers a little wrong, they are 68031850AI and 68229251AA. Even though some web sights will lead you to believe they have the hoses and allow you to put them in a cart thinking "Finally found them", when I called to double check I got: They are on back order... Another bust! I may have possibly located them in a Canadian parts store, but of course they would not ship international.
What an incredible PITA!
metalchewy
Las Vegas
2010 TRX4
4.7L
Both part numbers show as available on Amazon. (68031850AI and 68229251AA)
