Help Support Ram Forum by donating:
Power Wagon Down!
Discussion in 'Dodge Ram Power Wagon' started by 56PW17, Aug 6, 2019.
  1. Tpettit
    Tpettit Member Military
    53
    44
    18
    Mar 31, 2019
    Lake Stevens WA
    Ram Year:
    Engine:
    Still running. At highway speeds, I can feel it stuttering, uphill or under load obvious misfire. No check engine light and no other alerts. Was supposed to drop off at dealer today.. no go. They didn't have a loaner available.
    McBroom likes this.
  2. 56PW17
    56PW17 Senior Member
    30
    573
    355
    Feb 11, 2018
    Pa
    Ram Year:
    Engine:
    That is interesting no check engine light
  3. McBroom
    McBroom U.S.Marine Veteran Retired 88-2000 Military
    49
    4,341
    4,707
    May 25, 2017
    Denison Tx
    Ram Year:
    Engine:
    Hemi 6.4L
    I bet it’s the mds solenoids
    The Blue Mule
  4. Tpettit
    53
    44
    18
    Mar 31, 2019
    Lake Stevens WA
    Ram Year:
    Engine:
    1st dealer I took it to also said it was interesting that there was no check engine alert. More interesting is that they said it was definitely misfiring. Wonder if they pull up codes that indicate that? And why would they say it was fixed when it definitely is not? Aggravating....
  5. yoda
    yoda Senior Member
    49
    362
    154
    Jul 25, 2016
    Ram Year:
    Engine:
    I've had a couple 6.4s with bad EGR valves with similar symptoms. Studder/hesitation on light accel. No DTCs.
    Did they actually drive it with a scan tool hooked up and monitor for any miss fires?
    To much EGR flow will feel like a miss but usually The pcm will not count any misses.
    Try unplugging the EGR and driving. (The Check Engine light will come on)
    Tpettit likes this.
  6. 56PW17
    30
    573
    355
    Feb 11, 2018
    Pa
    Ram Year:
    Engine:
    Update..
    So they replaced the head and it seems to have gotten the misfire code to clear. That is a good thing. Still working on the major evap leak. Might have it back by next week! That would be so awesome
    Trailmaker, michael harpe and Tpettit like this.
  7. Trailmaker
    Trailmaker Senior Member
    160
    115
    Jul 28, 2019
    Conroe Texas
    Ram Year:
    Engine:
    Might as well keep if they are rebuilding your engine, plus warranty.
    56PW17 and michael harpe like this.
  8. Tpettit
    53
    44
    18
    Mar 31, 2019
    Lake Stevens WA
    Ram Year:
    Engine:
    Tech I spoke with said he drove it with a laptop hooked up. I believe that's how he confirmed that it was misfiring. Was told all it needed was a, I believe he said PCM reboot? Honestly, on these new beasts, I wouldn't even know where the EGR might be hiding. Let alone unplugging crap and having the dealer say I did "unauthorized" troubleshooting and void the warranty! Just sayin... nowadays, you never know ;) But thanks for the reply and info!
  9. 56PW17
    30
    573
    355
    Feb 11, 2018
    Pa
    Ram Year:
    Engine:
    Update....
    Look like they solved the misfire codes with all the replacements they did.
    It also appears i had a cracked valve on my gas tank that was causing a major evap leak. They are replacing my tank today. I think i will have the truck back on friday.
    I really can’t wait. Been 50 something days.
  10. Trailmaker
    160
    115
    Jul 28, 2019
    Conroe Texas
    Ram Year:
    Engine:
    You just need the new car scent added and you will feel like you did when you first got it. :)
    Looks like they came through for you and covered some non covered items along the way?! ( not sure what your warranty covers)
Share This Page
