PPE pan and zf Fluid change last question.
stenerson
New Hampshire, USA
3.6 VVT
Okay. Got my PPE pan, new screws, bought a new gasket, fits nicely. Bought a chemical sprayer as transfer pump. tools ready. Plan to do this tomorrow. From videos I've seen I notice the stock gaskets seem to have a metal sleeve. Do I transfer those over to new gasket/pan?
Most guys do. Have you got some tall jackstands as you need the rear of the truck in the air a fair height to level the transmission. 3 ton stands usually aren't tall enough.
EdGs
FL
If you're talking about the metal sleeves for the screws in the old pan, I would transfer those to the PPE. They will keep the gasket positioned.
Remember to crack the fill plug loose BEFORE draining the trans. Those fill plugs were all tightened by Hercules, afaik.....lol.
Good luck, may your service go smoothly.
stenerson
stenerson
New Hampshire, USA
3.6 VVT
Remember to ctack the fill plug loose BEFORE draining the trans. Those fill plugs were all tightened by Hercules, afaik.....lol.
Thank you sir! Gasket seems pretty thin in certain spots. It's fel-pro brand. Not sure if the mopar is the same. Will see.
Yep, I bought new 6 ton jack stands a couple weeks ago.
Just to add to Ed's advice keep a bucket of water handy so you can soak some rags in it,and lay them over the exhaust,helps keep the cursing and swearing down when you're doing the final check :Big Laugh:
The 122F is the max checking temp,ideally you'd like to do the final check with the transmission between 100F and 105F,so the colder the transmission is when you start,the better off you'll be.
stenerson
stenerson
New Hampshire, USA
3.6 VVT
I got the 3.6 vvt so the exhaust not as much of a problem. I waited a few weeks to do this in cooler weather, (days starting off with a hard frost), figured that would make it easier. I printed out the instructions to have them handy.
EdGs
FL
Some have said that the sleeves are a lttle tight in the holes of the PPE pan, might wanth to have a small round file if needed.
A little snug is good for the sleeves, that way they wont fall out, as long as they do not get misshapen transferring them.
Good idea,it doesn't hurt to start the drain process the night before,and let it drain overnight,then do the pan/filter swap in the morning when it's cool.
Atcer2018
Virginia
I installed a PPE pan on my 3.6 and transferred the metal sleeves from the OEM pan. They are a tight fit but very doable with a small block of wood and mallet for the stubborn ones. Follow WildOnes directions and it’s a fairly straightforward procedure. One more tip you may consider is chasing the threads on the pan rail. I live in the southern US and still had some corrosion that would impede the bolts when installing. You’ll see when you remove the old pan that the threads do not bottom out inside the pan rail, they go through it and are open to the atmosphere on the back side. Hope it all goes well for you.
That's a good idea about chasing the threads Atcer. :waytogo:
MRFREEZE57
pacific northwest
I used the metal sleeves, just had to ream a few of the holes in the PPE as they were very tight.
So if you use gasket maker then two days with no truck? As they want you to wait overnight to fill. So use traditional gasket? I must admit, I do prefer the gasket maker, never had a leak with it but I have had gaskets leak.
The pan uses an rubber style gasket,so they don't really need any help in the sealing department
lAWROSA
GALIVANTS FERRY SOUTH CAROLINA
I had ram do mine. I bought them the pan and all. Cost me about $400 bucks... When I installed the bypass in the trans I saw and smelled the small bit of fluid that came out and it was awful.. Hence why I changed the pan with PPE, replicable filter, and fluid.
SpaceRanger1
2017 Ram Rebel
I have a 2017 Rebel 302K on it.. Around 205K i replaced with a PPE pan. Used a new OEM gasket and have had leaks ever since..
Also, Where do I get the Thermostat Bypass from.. Getting ready to replace the Pan filter, Plugs as well.
Thank you for the help.??
Unless you got a bad pan,the leaks are probably something you've done,as my PPE pan has been off/on about a 1/2 dozen times and i've never had any leak issues.Did you replace the o-ring gasket with a legit OEM gasket from your local dealer.Take a machinsts ruler and use it to check the pans flange for straightness
Hunt up @caulk04 as he'll give you a link to where you can buy his bypass
stenerson
stenerson
New Hampshire, USA
3.6 VVT
I ordered a new aftermarket (fel-pro) gasket to use with my PPE. It's been several months, no leakage issues yet. Though to be honest the original gasket was in great shape, I'm confident it would have worked fine. I tightened by feel, was very gentle. Almost 4 months, so far so good.
I bought the thermostat bypass. Haven't installed yet, plan to do in spring.
Wow! You got 302K on your truck? Nice!
Fryekenn
