Project: Handle Like a Porsche!
Trupiano
Trupiano
Registered User
Hometown : Puyallup,WA Stationed : Little Rock,
2010 Ram 2500 6.7L CTD Crew Cab
6.7L CTD
Trip,
Bit of an overkill. I did mine with help on a rack in about 4 hours not counting the sway bar and bags. However since you have the bed off what about going ahead and getting the "c" notch done?
DodgeTalk : Dodge Car Forums, Truck Forums and Dodge Ram Forums
As you I hijacked these pictures, but this is something I'm planning.
Cant do a C-Notch. 2/4.5 is as low as I can go with a 4wd. 3/5 and 4/6 drops use the C-notch. If I go that low, Ill destroy my CV joints. It might be more than I need, but it couldn't hurt.
Trupiano
Trupiano
Registered User
6.7L CTD
You may not have to pull it out of the stall each night. Most of the hobby shops have a $2.50 fee to store it inside overnight.
Would be nice! I still have to inquire, cause Ive never used the stalls for over 3-4 hours. But hopefully your right. The install will go alot faster if I have help, but I'm not sure cause most of my buddies work dayshift down in my hangar, and the shops only open 8-7.
RubberFrog
This is going to be sweet. Definately take lots of pics. Having the bed off will make for great shots for others to understand it better.
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
Trip, with the bags you will be good. Just hate not taking advantage of having the bed off. lol
Trupiano
Trupiano
Registered User
6.7L CTD
Helper Bags are here. Here's a shot
I also received a brand new set of McGaughy's 2" (really it's 1.5") drop shackles. Will sell for $40 plus shipping(prolly 3-6 bucks) if anyone wants them.
AWE Daniel
Banned
will those work on a 2wd? I might be interested if its easy to do.
AWE Daniel
Banned
im interested just wanna know how they go on, if I remember its not too complicated.
Trupiano
Trupiano
Registered User
6.7L CTD
1. Lift the truck, put jackstands under the frame in front of the rear suspension.
2. Remove the tires.
3. Jack the rear axle up a lil to relieve pressure on the leaf springs.
4. Remove the bolts on the shackles on each side.
5. Grease the new drop shackles a lil.
6. Install them and lightly tighten the bolts.
7. Reinstall the tires, and unjack the truck.
8. Torque down the Shackles bolts.
9. Retorque the bolts after about 500-1000 miles.
Not too complicated.
AWE Daniel
Banned
Cool man I gotta think it over if I want to lower it ill keep you in mind
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
Don't need to remove the wheels, I didn't when I installed a set on my 08.
I put a drop hitch in, jacked up the rear from there. Got under the truck, removed the bolts and shackles, reinstalled new ones.
OklaHemi
new age hemi
trup i cant wait to see this done. you truck will be complete then.
glass3222
Central PA
The auto hobby shop is one of the things I miss most now that I am not in the army anymore :(
OklaHemi
new age hemi
Dude I'm so ****** stoked to start this project! These parts can't get delivered fast enough! Never be complete... :headbang:
yeah i know, but visually your truck needs this.
Redtruck-VA
Virginia
Trip, you are doing this the right way and are going to like everything about the new ride.
