Pulsar Inline tuner and using an aftermarket radio using iDatalink Maestro issue!
GettinOld
Canada
Hi there!
I was wondering if there is anyone out there with a 4th gen Ram that has an aftermarket stereo (including head unit) and using a Edge/Diablo Pulsar Inline tuner? The tuner is controlled via the steering buttons to change the power levels. As you change the levels, the mode #'s changes as normal (numbers 1 thru 8 besides the D on the instrument cluster). It is also supposed to overwrite the audio display at the top center of the cluster and actually displays the model level as well (ie, Stock, Stock w/o MDS, Performance, Perf w/o MDS etc).
Well, its not in my truck! The numbers change by the gear selector 'D' (1 thru 8) but not the power model level in words at the audio section. I believe its because my obd communications go through the iDatalink Maestro module that retains all the factory features in the stereo (which works flawlessly by the way). It seems that the Pulsar PCM can't 'speak' to the instrument cluster via the maestro to display the power level in the audio section of the instrument cluster display. Anybody out there has the same issue? Any fix? BTW, i did change the OEM setting on the radio to disable the OBD communications (gauge, TPMS, etc) and doesn't fix the issue.
Anyways any help would be helpful.
Cheers.
DILLIGAF
Canadian Forces
Canada
The fix is get HP tuners and a custom tune. ;)
G
GettinOld
Canada
So, I ended up pulling out my aftermarket deck and pulled the maestro for a bit. I plugged in the factory 8.4 headunit and still didn’t get the power mode level to display in the instrument cluster display?? Maybe it’s the pulsar unit itself.
diymirage
Banned
Last I checked pulsar used the cruise controll buttons to cycle through
G
GettinOld
Canada
Yes, it does. I see the number 1 thru 8 by the D on the cluster when I use the cruise set(-) and res(+) but the words Stock, Stock No MDS, Economy, Econ No MDS, etc should also display on the cluster where the audio metadata is shown briefly while you scroll the modes. It’s not. Because it’s not displaying the modes, it’s not displaying the setup words either (Tire size, gear ratio etc).
Welcome to the world of $h!tty Holley owned products.Holley owns both Edge and Diablo and ever since they aquired both company's,their products have gone downhill
