quick fix for alpine 10 speaker system?
clays laramie
hemi
I was wondering if just a dsp will make a big difference in sound quality.. just spent 50k on a new truck and dont want to spend a ton moreor tear everything apart...idea's?? How about a plain amp swap?? Do they have 10 channel amps?
Thanks in advance..
clays laramie
clays laramie
hemi
Thought the system would be better than this...
cc rider
Western NY
i agree. i got the "upgraded" speakers. Not happy. See several posts about replacing their speakers /sub
Power247
High Point, NC
6.4 HEMI
There is no plug and play amp to replace the alpine that will make a significant difference. Kicker makes one but the specs are not that much better considering the cost. Most who add a DSP also add aftermarket amps. There is a guy on here named dengland that is using a JBL MS-8 to tune and power all (or at least most) of the factory speakers. He is a member here but his main build thread is on another forum. If you are considering going this route his thread is definitely worth a read.
I replaced the factory sub with an aftermarket amp and 2 10" subs. Obviously this made a big improvement but for my taste in music I wish I had gone with 12's.
I also replaced all of the dash and door speakers with Infinity Reference 2ohm. This made a HUGE difference in the overall sound quality and volume of the system. The 'premium' speakers are also 2 ohm so using 2 ohm replacements will make sure you are getting all you can out of your factory amp.
I picked up all 3 sets plus adapters and harnesses for under $300. If I was to start over I would have do this first.
Here is a link to my build thread if you are interested Upgrading the factory alpine system
clays laramie
clays laramie
hemi
Thanks power 247 ..i thought i read somewhere the dash speakers were 4ohms?? Theres a kicker kit for 160$ all three fronts and front doors..seems to good to be true...must be low models.
autokraftgt
Hemi 6.1
Thanks in advance..
Yes, a DSP will improve sound quality...will it be a "big" difference? That's subjective, but a dsp will help improve sound.
More power will always help improve sound as well.
Higher performance speakers will help improve sound too.
you see a trend?....simply depends how much you are willing to spend, and what level of performance will make you happy in the end.
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
There is a kit called 77KICK42 that will replace doors and all three dash speakers. Adding a DSP to an amp that Alpine already has a DSP in will be fun to tune.
BradKnob
Prairieville, LA
What exactly is it that ur unhappy with? Volume, clarity, imaging etc etc? If u tell what exactly you would like to improve, we can probably help guide you a little better.
clays laramie
clays laramie
hemi
The highs dont sound clear or spot on.. are all the 3.5 speakers 4 ohm on the 10 speaker system?? I hope so.. just orded 2 pairs of kickers... wish they sold a 5 pack haha.
ironhead3fan
2013 Laramie
I added the 77KICK42 to the dash and front doors. I will have to say that those really increased the front bass and highs. After the last firmware update to my amp and stereo, the system really rocks now. Hoping to get the 77KICK41 for Christmas to put in the rear doors. Overall, I am pretty happy with my system now, and the rear door speaker upgrade should really make the difference.
BTW, there is enough bass in the system with the 77KICK42 upgrade that I don't feel the need to upgrade the subwoofer now.
