Ram 5.7Hemi Coolant Flush DIY
LeesEvoX
Houston, TX
Hemi 6.4l
Does the coolant flow into the block from the top of the radiator? Or the bottom?
Hemi395
Hemi395
Cape Cod MA
The bottom. Hot coolant comes back to the radiator through the tstat into the top of the radiator.
LeesEvoX
Houston, TX
Hemi 6.4l
You're a good man Sir thank you.
So I think I'm gonna remove the Tstat. Remove the upper hose from radiator. Plug it. Run hose from Tstat to bucket. Start the truck up, and just constantly run water through it till clean. Doing this MUST flush it pretty much 100% right?
S0CAL
US Marine Veteran
The Lonestar State
2021 Limited Longhorn CTD HO DRW 4x4
Cummins 6.7L HO
Just pull the Tstat but leave in the gasket, reassemble. If you don't care about the mineral deposits from the tap water, your plan sounds perfect. Alternatively, pull the Tstat, but leave in the gasket, drain the petcock, refill with gallon jugs of distilled water. Run engine for a few minutes, drain/refill until your drains are clear. This takes you through the entire system. I did it 5 times to get to clear. Roughly 10gal of distilled water.
Hemi395
Hemi395
Cape Cod MA
Thanks!
Yeah that should work pretty well. If you do flush it that way, please post up how it went!
R.L.K.
Bristol , Tn.
If your planning on running tap water from a hose for the flush , just make sure you take diligent steps to replace the tap water with distilled water . Tap water will likely cause significant corrosion .
Good luck Sir !
Hemi395
Hemi395
Cape Cod MA
^^^THIS! Distilled water only! There's a lot of aluminum components in the Hemi that tap water could corrode...
LeesEvoX
Houston, TX
Hemi 6.4l
Don't worry ya'll. I'll be using distilled water lol.
Will hopefully do this at the weekend. And shall let you know! 113k miles. She is due.
Plus we plan on leaving April 16th for our trip to CA, and this is literally the last fluid that needs changed.
Jwithing
STL
I'll tackle this today if I can get off my lazy ass lol. I'll let you all know how it goes.
LeesEvoX
Houston, TX
Hemi 6.4l
Question. I. Noticed that the upper radiator hose on the truck is damn near flat from vacuum in the morning.
Is this a sign of a bad radiator cap?
Hemi395
Hemi395
Cape Cod MA
Honestly don't know if thats normal or bad. I've never noticed mine doing that but I've also never checked it before a cold start...
LeesEvoX
Houston, TX
Hemi 6.4l
Yeah from looking around it looks like the radiator cap is rated for a certain psi. And the spring inside helps release vacuum, and coolant Into the overflow.
It's strange that's for sure
Jwithing
STL
Can you just use some plieres to unthread the petcock? Or isitgere something internal to the rest of the petcock that requires an allen key?s Didn realize how huge a 3/8 Allen wrenches was and don't have one handy.
Hemi395
Hemi395
Cape Cod MA
Can you just use some plieres to unthread the petcock? Didn't realize how huge a 3/8 Allen wrenches was and don't have one handy.
You probably could or try a larger socket to go over it. Either way be care it's just plastic...
Jwithing
STL
Tried that and it started stripping, it doesn't quite seem to be a standard or metric socket size
Jwithing
STL
Well, the pliers worked... Didn't have a drain hose and it was a bit windy splashing around into my bucket... Got some in my mouth... Yummy :33:
Hemi395
Hemi395
Cape Cod MA
Lol that sucks. Is it sweet like the older green coolant?
TMFMK
