RAM CARES and DRAG LINK RECALL !
Brian2081
Weatland Michigan
Hello All, chri5k is correct, the whole issue with the drag link is the TURNBUCKLE !!. It appears when some of the turnbuckles were machined the hole was oversized a few thousandth, then when the threads were cut they wound up being to shallow allowing the drag link ends to jump threads inside the turnbuckle, hence giving the illusion that the jamb nut(s) backed off when they had not. The nuts are good so they are using them as an extension of the turnbuckle by doing the welding.
The big problem is FCA does not know when this screw up happened.
I agree this should only be a temporary fix till FCA supplies the new draglink. Or you replace the draglink or turnbuckle and provide proof of said fix to FCA, at which time they should reimburse no questions asked. But we know how that goes.
Crazy Jerry don't call out people unless you KNOW what you are talking about. I got my info from an old friend who works at FCA headquarters.
wallacemf
2500 4x4 Hemi 6.4
We can get you a new drag link in order to close the recall. To get started, send us a PM with your VIN and dealer info.
Kaitlin
Ram Cares
PM sent, and thank you for your help!
RamCares
n/a
n/a
on friday i had the welded drag link replaced on my 18 2500. replaced with 68338342AD mopar. all good now. ill submit the receipts to ram, but doubt anything will come of it. in principle, welding an adjustable part on a 55k or more truck is beyond embarrassing. i am a small construction business, and can write off the link as vehicle expense. cheers comrades!
If you need any help with the reimbursement, we are happy to look into it for you.
Kaitlin
Ram Cares
wallacemf
2500 4x4 Hemi 6.4
Just wanted to give a "shout out" to Kaitlin @ Ram Cares....
It took a couple of months but I finally received a case number and the replacement drag-link should be at my local dealer in a week or so!
THANK YOU KAITLIN !!!!
Same here, my case was opened around Christmas. I had appt at the dealer this morning to complete other pending recalls.
They confirmed the case was open with FCA, they checked and had an updated drag link already in stock, so they installed it.
Thanks, Kaitlin!!
BillyGoat
SE MI
I brought my 17 PW to the dealership earlier this year because the ram boxes warped. They completed the recall and welded the nuts when I explicitly told them not to touch it. FCA denied my claim for the replacement. They pretty much stuck it in my ass.... no solution. So recently I brought it back for an alignment and they told me an extra $150 to remove the welds and re-weld. They can stick it up their ass this time, I am 100% done with FCA **** products....
Once you drive a 64k truck off the lot, customer service typically sucks. Always an ordeal everytime....
Kaitlin, please help! I just want the new part....
GsRAM
2017 Dodge Ram 2500
Hemi, 6.4L
Send Katilin @RamCares a PM with all of your info, and your trucks VIN and I'm confident she will assist in getting yours replaced.
It stinks and I fought this for a year almost but in the end, FCA made it right and replaced my drag link and I'm a happy ram customer again. Good luck man.
RamCares
n/a
n/a
Hi! Send a private message with your VIN and dealer info and we can get started on a new drag link.
Kaitlin
Ram Cares
RodeoRam
Supporting Member Air Force
North Carolina
Hemi 5.7 2500 CC
And that is why I bought the Synergy drag link. Why should I buy a drag link from the same company that gave us the original junk part? If the new Mopar drag link had problems, too, it would be my own fault for getting it.
BillyGoat
SE MI
What is the difference between the old and new drag link? What changed?
Thanks,
BillyGoat
SE MI
Cool, thanks. Looks like a much better design similar to the synergy link. This should be a no-brainer for FCA to replace all those affected... total BS
BillyGoat
SE MI
Kaitlin
Ram Cares
Sorry, dumb question, but I do not see the option to send you a PM....thanks!
Bldrinker
How can I get the new drag link. I haven’t took my truck in for the recall because I don’t want it welded.
GsRAM
2017 Dodge Ram 2500
Hemi, 6.4L
Send a PM to Katilin @RamCares and she will assist you.
You will need to provide her with your full name and mailing address, your local dealer name and the VIN of your truck. Good luck! She's great and has helped many of us get the defective link replaced.
RamCares
n/a
n/a
Hello, feel free to send us a private message with your VIN and dealership like the others have said and we can help.
Kaitlin
Ram Cares
Bldrinker
Kaitlin
Ram Cares
I got a call this morning. They are trying to get me an appointment.
