Ram Weight?
Darkknight3829
How much does my 2010 Dodge Ram 4.7 Regular Cab Short Bed, ST trim weigh? going to the track friday. Need to know if my trailer is rated for it. Thanks
Darkknight3829
Darkknight3829
Thanks! Sorry about this but what is GVWR? says 6,200. Is that the weight, or is it 4,674 where it says total weight?
Darkknight3829
Darkknight3829
GVWR i believe means payload. I just want to be sure
Darkknight3829
Darkknight3829
Alright cool.. i should be good then! trailer is rated at 3,500 an axel. dual axel.
jlb
MT
CTD
GVWR is the max weight it can legally weigh including cargo, people, fluids, etc.
The curb is likely the 4,600 lb number
Musclemckeester
Houston, TX
n/a
n/a
Watch out on that, my dual 3,500 lb. axle trailer is really only rated for 5,500 lbs. When I bought it I thought it would haul 7k, but I was wrong. Even still you're way under it as am I, where the heaviest thing I'll ever haul is a Jeep about the same weight as your truck.
craigsez
Novascotia,Canada
Go to a truck stop and scale it or stop off at a dot (big rig dept of trans)scale and go in and ask if they will weigh it as is..
