Rambo, Old farts last build
Evguy1
Evguy1
Errington BC
2014 RAM1500
Cummins ISB 170
I'm not an elegant welder but I can stick stuff together. ;>) The oil pan is mig welded on the outside and then brazed on the inside to seal it up and then a coat of POR15 tank sealer inside and out for good measures.
Evguy1
Evguy1
Errington BC
2014 RAM1500
Cummins ISB 170
Well, adapter got finished this week so I got the engine bolted in for the last time, I hope. Now its time to start bolting accessories on and wiring it all up.Rambo passenger mount.jpg
hodge-xj
5.9 cummins
I love this build! All the "outside" the box stuff is awesome
Evguy1
Evguy1
Errington BC
2014 RAM1500
Cummins ISB 170
Got some brackets built and pulleys mounted today. Took three idlers to get good belt wrap and keep the belt tight to the engine. I'm using the Hemi alternator and A/C compressor along with a Ford vacuum pump.Belt routing.JPG
NOV87
PNW
That's impressive! Thank you for finding time to take pictures and post updates.
That small panel cover on the left side of the full floor console
I see that you fitted a switch into it.
Those little clips that hold it in place are very fragile
I broke mine the 2nd time that i opened it
i had my 2009 Ram setup the same way
Evguy1
Evguy1
Errington BC
2014 RAM1500
Cummins ISB 170
I did notice that the panel did not snap back in place on one end. Should be able to epoxy a small tab to the backside once I get back to interior stuff.
Evguy1
Evguy1
Errington BC
2014 RAM1500
Cummins ISB 170
4" downpipe is a bit of an overkill for this engine but its what I had to start with.Rambo downpipe.JPG
Evguy1
Evguy1
Errington BC
2014 RAM1500
Cummins ISB 170
Got the trans heater/cooler thing bypassed and new cooler lines made. 1630199531205.png
Evguy1
Evguy1
Errington BC
2014 RAM1500
Cummins ISB 170
Started to tackle the wiring this weekend. The Cummins ECU harness only has 38 wires to deal with on the chassis side so I'm starting with that and almost have it done. Once its finished I can fire the engine as a stand alone system, hopefully this week.
Next step is to tackle the Ram harness which is a bit more challenging. :(
Evguy1
Evguy1
Errington BC
2014 RAM1500
Cummins ISB 170
I wanted to have a whole separate battery system for the Cummins, I did this on my Dakota build and it was great. A few times we got back to the truck and the main truck battery was dead. The separate battery was isolated from the truck so it always started. Finding a spot for the second battery was interesting and I ended up going under the passenger floor on the outside of the frame. I'll install a jump plug in the grill so if it needs a jump it will be easy.rambo battery installed.jpgrambo battery.jpg
Evguy1
Evguy1
Errington BC
2014 RAM1500
Cummins ISB 170
After 8 months of work the truck finaly made it maiden voyage. On Friday I was shure I would not get it drivable in time but after a late night remote transmission tunning sesion with Russell at Sound German Auto I had a usable truck. It still needs lots of fine tuning but it made the 2 hr tow with no problems. That Cummins/8 speed combo works very well. We had a couple of low mountain passes to get over and had no problemTofino.jpg, hardest problem was keeping my foot out of it. :>)
Evguy1
Evguy1
Errington BC
2014 RAM1500
Cummins ISB 170
We have traveled a lot of North America but 2 hrs from home is pretty special!
Still a LONG way from "sorted" but a good start.
KwyjiboJonesJr
